Engine revs much higher before moving after stall installed
Old 12-21-2006, 06:31 AM
koolaid_kid's Avatar
Default Engine revs much higher before moving after stall installed
I recently installed a Fuddle 3400 STR2.1. Yeah, I know; I purchased it before all the issues started up.
The engine revs to around 2200-2400 before it starts to move. Is this normal?
Also, when moving down the road at a steady speed, I can lift the throttle and then reapply and the revs will drop about 200 rpm (when traveling about 40 mph).
Other than these 2 issues, I like it, although I only have around 500 miles on it at this time.
Old 12-21-2006, 06:38 AM
spy2520's Avatar
stall converters will cause you to give it more gas to move, the converter doesnt transfer too much torque before its stall speed.
second issue, is when cruising your car should be in lock-up at 40 (since you have 3.42s). i have 3.23s so mine usually locks up close to 50, but when you let off then hit the gas it will rev a small amount then drop back into lock-up usually.
the issues you are experiencing are normal, i have the same exact converter by the way.
Old 12-21-2006, 08:58 AM
LS1Tech Sponsor
performabuilt's Avatar
Different types of converters will of course have different characteristics but that sounds pretty much normal for that level converter .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-21-2006, 09:33 AM
Joel_SS's Avatar
Welcome to a loose converter.
Old 12-21-2006, 11:24 AM
Camaroholic's Avatar
The only other thing to do would be to check your fluid level. If it's a bit low, that can cause slippage like that. Check with hot trans, level ground, engine running.
But yeah, that's what a loose converter does.
Old 12-21-2006, 11:39 AM
Jordan S.'s Avatar
Every fuddle car I've rode in is like that. Loose as hell. That dropping rpm's might be it locking up.
Old 12-21-2006, 05:14 PM
BlackHawk T/A's Avatar
That's how they work, they slip quite a bit. Should have done your research before you spent the money
But i'm sure you will get used to it.
Old 12-21-2006, 05:34 PM
GT Griller's Avatar
Floor it!!!! I guarantee u will love it
Old 12-21-2006, 06:33 PM
nikon1999's Avatar
Old 01-01-2007, 11:09 AM
1BADTALS1's Avatar
^^^ YEAH BABY!!!!!!!! i also have the fuddle and bought it b4 all the problems started but i just got used to it.
Old 01-01-2007, 11:36 AM
Pontiacerator
RevGTO's Avatar
2200-2400 rpm at what level of throttle input? If you just feather it, will it move out? If so, how high do the revs go?
Old 01-01-2007, 11:51 AM
sixvi6-camaro's Avatar
The Fuddle 3400 I had was super loose. It would barley roll when I took my foot off the brake and took 2500-3000 rpm to acelerate with normal traffic with 2.73's so yours sounds about normal.
Old 01-01-2007, 08:56 PM
zspot98's Avatar
It's the Fuddle. They seem to make loose converters. I gotta get my 3600 to around 31-3300 before she moves.
Old 01-01-2007, 09:24 PM
Frost's Avatar
It ought to be a good fit for that rear mount turbo and make car much quicker through at least first gear.... boost will always be available now.
Old 01-02-2007, 12:00 PM
That is not normal. If everything is installed correctly and your fluid level is correct (low will slip more) there is something wrong with that converter.
Mine starts moving at 1800-2200rpm.
Old 01-02-2007, 04:45 PM
zspot98's Avatar
TC is installed correctly and the fluid is good. That's why there's a Vig going in soon.
Old 01-02-2007, 06:24 PM
Moderator
JNorris's Avatar
This is not normal. A 3400 stall should creep forward while in gear without touching the gas. Check the fluid and be sure it is full.
My 4000 stalled car moves at 1000rpm.
John
Old 01-02-2007, 06:55 PM
chris93266's Avatar
congrats mission accomplished. your car now stalls.
Old 01-02-2007, 07:07 PM
John
I think there is a misinterpretation here on what we mean by "moves". Sure the car will pull itself forward, but at 1mph you really aren't going anywhere.
2200rpm sounds right for that converter, as far as RPM required to start accelerating as you would during normal driving.
Old 01-02-2007, 07:15 PM
Ragtop 99's Avatar
At 2400 rpm, a 3400 stall should be moving very crisply on a car with 3.42s.
Man that's a loose conevrter. Even with my YTP 4200, at 3300 rpm I was pulling away from anybody not trying to race me.
