4l60e pump
Old 02-19-2007, 08:06 PM
black99ls1's Avatar
Default 4l60e pump
does anyone have a pic. that tells how the valves go in the pump.
thanks
Old 02-19-2007, 08:20 PM
LS1Tech Sponsor
performabuilt's Avatar
Oil Pump & Related Parts
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-20-2007, 09:17 PM
black99ls1's Avatar
thanks for your help performabuilt.
now i have another problem my new pump doesn't want to go down in the trans. The old bottom half will just drop right in the new one won't. any ideas why.
thanks
Old 02-20-2007, 09:31 PM
LS1Tech Sponsor
did you put new rings on the stator ?
__________________
Call 888-744-6542
Old 02-20-2007, 10:13 PM
black99ls1's Avatar
yes i did
Old 02-21-2007, 06:25 PM
black99ls1's Avatar
it makes it pass the first ring then it get between the two rings and stops. it sounds like metal to metal if you try to tap it in. i have looked at both pumps and i cant seem to find any differences between them.
Old 02-21-2007, 06:33 PM
LS1Tech Sponsor
how did you align the pump ?
__________________
Call 888-744-6542
Old 02-21-2007, 06:37 PM
black99ls1's Avatar
with the bolt holes
black99ls1's Avatar
matched the holes of the pump to the holes that are in the trans
Old 02-21-2007, 07:02 PM
LS1Tech Sponsor
Ill send you the right way to do it with the tools you have in just a little bit ok
__________________
Call 888-744-6542
Old 02-21-2007, 08:11 PM
black99ls1's Avatar
ok thanks
Old 02-21-2007, 08:40 PM
LS1Tech Sponsor
PM sent
__________________
Call 888-744-6542
Old 02-21-2007, 10:23 PM
black99ls1's Avatar
Yay i got the pump in, i will be installing the trans tomorrow night. thanks for you help performabuilt i couldn't have done it without you.
Old 02-21-2007, 10:28 PM
LS1Tech Sponsor
Your welcome
__________________
Call 888-744-6542
