4L60E lockup switch ?
Old 04-25-2007, 08:45 PM
THEE PEWTER Z™'s Avatar
Default 4L60E lockup switch ?
Anyone have one, i want to put one one my 99 so i can lock the converter when i want too.. anyone have any installtion instructions or any input
Old 04-25-2007, 08:49 PM
'Trust''s Avatar
sounds kewl, could help me out in my city driving!
Old 04-25-2007, 09:12 PM
6-Speed Terror's Avatar
pin 42 tan /black on the red connector is the tcc enable circuit i would say try grounding that might work
Old 04-25-2007, 11:45 PM
orangefun's Avatar
would an 01 car be the same pin?
Old 04-26-2007, 12:20 AM
yeah only 98 pcm's are diffrent
Old 04-26-2007, 12:36 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes it would be but grounding that wire will not guarantee lockup at least not full lockup , Its one enables it with the pump , Unless the PWM has been in some way disabled you would have to also ground one wire from it to get full converter lockup , Otherwise you will only get a certain percentage of lockup as the PCM will allow at any given throttle
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-26-2007, 09:28 AM
Moderator
jimmyblue's Avatar
Off the top I would say you want a DPDT switch like:
side 1 - common to TCC solenoid on trans, NC to the
PCM TCC solenoid drive, NO to ground
side 2 - common to TCC PWM on trans, NC to the PCM
TCC PWM drive, NO to IGN +12V source
Then normally-closed (NC) will be normal operation and
the other (normally-open, NO) will be hard-locked with
full TCC duty (100%).
You might substitute a DPDT relay and drive the coil with
a cuter, pushbutton switch etc. and maybe add a LED
indicator just so you don't get hung up; if you are into
relay logic you could make it latching and unlatch with
the brake light etc. too.
Old 04-26-2007, 07:09 PM
GrandmasterCow's Avatar
anyone have any info on doing this for a 98 ?
Old 05-30-2007, 03:16 PM
jfm
jfm's Avatar
I lock my converter on the dyno only.
Pin 42 tan/black red connector is correct.I have the insulation on that wire stripped back a bit so I can attach an alligator jaw style connector that goes into a small box that has a light and a meter[shows 0-100] and an on/off toggle.A second wire from the box goes to a good ground.
When the car shifts into 3rd gear the toggle is turned on,the light goes on and the meter shows 100.You can hear the converter lock up in third and then the pedal goes WOT and you get a nice dyno sheet.
You could make it nice and simple by bridging a wire to the lock up wire[pin 42-tan/black] run that wire inside your car where you want it and connect to one side of the on/off toggle.The other side of the switch gets wired to a ground.Turn the switch on and the converter will lock.
WARNING-Never leave the converter locked when comming to a stop it will hurt the transmission.
Quick Reply: 4L60E lockup switch ?
