Help with tranny problems, lost 3 and 4
Ok, this is like my 7th 4L60E...
None of them have lasted more than a month and I never even took them to the track. The past few times I'll have about 200-500 miles on them and out of the blue i lose third and fourth gear.
The builder is reputable but I'm starting to wonder, two or three times maybe. But I'm on number I lost count.
Its vac modulated tranny.
Any suggestions or what stuff I should have him put back in it? Clutches wise.
LS1Tech Sponsor
There is no advanatage to a 700r4 over a 4l60e , they are the same trans except for the way there shifts are controlled. If your having so much trouble with the preent source of the trans or builder , Perhaps you hould consider another built trans a completely different unit ,Sounds like eithersomethings being built wrong or I have seen cases where there was some issue with the trans case or valve body that cause repeated failures.
__________________
Use a different builder, period. MAny peopel use the 4l60e without trouble once they use a good builder. A reputable tranny guy doesn't make him a reputable 4l60e guy. No offence to him, but it sounds like he needs more knowledge on the 4l60e
Well I've seen a car that runs a 700r4 he build run 9's all day. Hes an old man thats been doing it since the 50's. But I think your right.
I bought this transmission and it needed rebuild. It lost the 3-4 clutch pack the first time it went out. Then I paid my builder to rebuild it and its done it probaly 4 more times.
I have a QRC tranny that needs new frictions sitting in the garage I think thats where I'm going to take it.
"Dam, with all the money I spent rebuilding this same tranny I could have bought a performabuilt"
Quote from last night. It blew up on the motor too, I didnt even get to spray the bitch!
