Transgo Shift Kit Installed No 1st Gear Now
Transgo Shift Kit Installed No 1st Gear Now up date got 1st
I HAD A TRANSGO SHIFT KIT INSTALLED BY A FRIEND HE IS A TRANSMISSION GUY. NOW THE CAR HAS NO 1ST GEAR HE REPACED ONE OF THE Solenoids HE SAID IT HAD NO OMS ON THE BENCH.IT HAS ALL THE OTHER GEARS JUST NO 1ST.HE TRYIED SCANING IT AND SAID HE COULD NOT SCAN IT NO INFO. THE CAR IS A 94 CAMARO Z28
LS1Tech Sponsor
I would check that the valve behind the solenoid was properly installed. Also if you shimmed the servo make sure it wasnt to much this will cause a second gear start also and will result in buring up the 3-4 cltch also. With the car not running and in neutral wheels raised make sure you can turn the driveshaft in both directions, On direction will have a little more drag but you should be able to do it by hand. If your car has the plastic 1-2 acum pistion I have seen this happen also when you place the springs on the top and the bottom of the servo I have seen the servo break , This will allow modulated line presure to leak into the 2nd gear circuit and cause it to be applied in first gear. That would be something else to consider .
Hope this helps some
__________________
ok he going to pull the transmission tomorrow he said him and two other experts change everything that could be with out pulling the transmission even the wiring harness.computor tried putting it back to stock and still no 1st gear
LS1Tech Sponsor
I can tell you something is applying the band a crossleak. servo to tight etc, first isnt really even a gear from a clutch apply point of veiw its the forward clutch applied in the absence of any other clutch or band applied, Some one has reassembled something wrong.
__________________
well i havnt had a chance to look at mine yet but i have the same prob on a tranny that i built or i may could help you out....but i am pretty sure its a crossleak problem as he said
the 1-2 shift valve and spring are easily installed backwards and will go together just fine but you can't make the ***** have 1st gear!!! You can change it without removing the valve body by removing the solenoid and checking/changing the valve and spring > The spring should be in 1st then the valve > !!!Have fun
He Took The Transmission Out Today And Took It Apart He Said Everything Looked Gtreat In There He Going To Get Anothing Valve Body And Check It Out To See What Was Wrong Also Thanks For All The Replys THE 1-2 WAS CHECK AND THE SPRING WAS IN 1ST THANKS Al
