4l60e 2-3 shift problem!!!
OK guys, here's the story... 2000 LS1 Firebird; lid,LTS, ory, magniflow exhaust, tr224 cam, hpt, built 4L60e with a vig ss3600
Before the built tranny and the torque converter and TR224, car ran 12.80 @110 with 2.00 60'. After cam and tranny build and torque converter, 60 fts. are now 1.70's . Car shifts fine from first to second, second to third bounces off rev limiter - have to get out of the gas 3-4 times for the car to shift into third. Any ideas??? Do you think it could be a tuning issue or a transmission issue?
shift
a have it set at 5500 rpm to shift,when it shift it's fine hard just under wot i don't think a have any problem's with the tranny,if i drive it on the street and start off easy on the gas and then get on it hard it shift fine.thanks
LS1Tech Sponsor
Well sounds like you have some tuning issue I mean you cant completely rule out the trans but its sounds ok to me, You do realize and I cant tell you alot more as Im not A tuner that shift points are determined by several factors MPH,RPM,TPS,and others. I would try and look at the data stream and see if the shifts even being comanded when you have to set to happen. It sounds a little like you are doing what called by some hitting the stall wall.
__________________
my tranny is extremely sensitive to the fluid level. it was a pint low on fluid and would bounce off the rev limiter at wot on the 2-3 shift. i added fluid and brought it up to the full mark and now it shifts fine.
LS1Tech Sponsor
__________________
