No O.D.
No O.D.
I just put in a new seperator plate(4L60E),Tightened the 2-4 band.Now I have no OD,Could I have forgotten to plug one of the solenoids in or if the 2-4 band is to tight would that cause it?I'm dropping the pan in a few.It shifted fine before,Just want to get some input in case I don't see anything....................Paul
How did you tighten up the band?
Also, ensure that you installed the checkballs into their proper locations.
Not likely an electrical issue as you have not mentioned limp-in symptoms nor the MIL lamp being illuminated.
Why did you replace the valve body seperator plate?
And one ore thing..... where in the heck is Hudson Valley?
g
g
g
g
LS1Tech Sponsor
No it could not be a solenoid as you have the other gears. As was said misplaced or missing check ball. Also damage servo seals in particular the center teflon ring if a corvette servo come to mind or of course the obvious teflon ring on the OD servo.
__________________
Originally Posted by Vince @ FLT
Did you use the sonnax 4th servo? If so did you install the gold washer on the pin? This washer is about the size of a quarter. If you did not install it I believe this is your problem. Vince
Are you sure that you have replaced the separator plate with a comparable plate. Meaning is it correct for the same year as the trans that you are working on? I think that maybe one of two things have happened. It is possible that the feed hole for the 4th gear feed hole might be blocked by the gasket. Or maybe you rolled it over when you installed the valve body and created a leak. You also did mention in an earlier post that you were having an issue with a 1-2 shift. You could be having a band issue as well. I guess we will have to see what you find.
LS1Tech Sponsor
With the sonnax servo there should be a gold washer between the servo and the clip , Theres one under the clip to but its black metalic. The gold washer must be there between sonnax servo and the clip on the pin.
Originally Posted by DRIVER456
I think it is the sonnex servo.The OD was working fine until I changed the seperator plate.So tomorrow I'm going to put back the original plate and see what happens.I took it all a part and everything seems fine.And about the servo,There's the pin a spring a flat washer,This washer is thin and about the size of a half dollar,Then a C clip then the rest of the servo.Thanks................Paul
__________________
LS1Tech Sponsor
Unfortunatly no but it is a slightly larger diamter than the black washer but not quite as thick and it goes on the band pinon top o the E clip then the sonnax 4th servo goes in right after, It comes with the sonnax servo.
The black metalic one is there but no gold washer.Do you have a picture of this washer and exactly where it goes...............Paul
__________________
Yes thats the servo I have,But That washer is not there.When I took it off the first time I don't recall seeing a washer,Maybe I dropped it. I don't know.But I will put a washer there and try it before I drop the pan again.I just read that you can take out the 4th acummulater piston & spring and plug the feed hole,The feed hole,Is that that pin hole brass looking thing thats in there.Is that a good idea or no?.SO THE WASHER GOES AFTER THE C-CLIP THEN PUT ON THE SERVO RIGHT?.....Thanks again..........Paul
BINGO!! We have a winner.Look what I found on my work bench.I reread the posts and it is Vince.THANK YOU!! Have to say thanks to Frank too.I put that washer in and I have the car on jacks and went through the gears and I felt it bump into OD.I'll take it for a ride and post back.Man can't believe it was something so simple.And I'm not touching anything else if this works,No plugging holes or leaving anything out.Thank you everybody for you help.........Paul
Alright I have OD!! It was that washer.Thanks Vince and everybody that helped .I would have never thought it was that washer,Holy crap.That washer must have not been there before because when I shifted into OD it would go in,Rev alittle,Then go into OD.Now it goes right into gear ........Thanks again...............Paul
