not sure of it at all. They have the threaded end that goes into it, which is where im stuck. its such a tight squeeze to even get the lines up there, and I dont see anyway to get a wrench on them to tighten them up.
Let me ask you this question. Are there fittings in your trans that you are trying to screw the cooler lines into? If you have a way of posting a pic it would help me to see what you have.
Do you have the push in style fittings or have the been changed to something different? What year are you working on? Or do you have fittings that are on the lines and the case?
it was the 2 lines that thread into the top of the tranny. it took me a good hour to get them bitches started and threaded in all the way. you abrely have any room to work and get a wrench on them is the problem
