trans break
Old 11-01-2007, 01:19 AM
chevyls1's Avatar
Location: where ever i can store my car. (palos hills,il for now)
Default trans break
i was looking at the pro tree break with reverse manual valvebody. i am going to run a th400 in my car. is there any other breaks that you would suggest to get. i was told that the pro tree is the best.
thanks
cliff
Old 11-01-2007, 08:13 AM
FLT
FLT's Avatar
That's the one we would use. It is the fastest one on the market. Vince
Old 11-01-2007, 09:32 AM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
+2 on the pro-brake
Old 11-01-2007, 09:34 AM
dochall22's Avatar
can someone explain to me the differene in a transbrake and a line lock and what each is used for? thanks!
Old 11-01-2007, 09:42 AM
red83's Avatar
they are installed on complete different parts of the car.
a line-lock locks your brakes. mostly for burnouts.
a trans brake is in you automatic transmission. it allows you to get the full potential out of your converter and in most cases better 60 ft times.
Old 11-01-2007, 09:44 AM
bjamick's Avatar
Trans brake, when the button is pushed and the car is in gear it locks the tranny in between reverse and first. WHen you let off the button it engage completely into first gear. Just like dumping the clutch in an M6.
A line lock locks the front brakes so you can do your burn out. I wouldn't turn your line lock on at the line or you will forget and when you give it gas its prob not gunna go very fast ..
Old 11-01-2007, 09:48 AM
dochall22's Avatar
interesting....
Old 11-01-2007, 10:08 AM
bjamick's Avatar
Well that was a quick explanation but there ya go that kinda sums it up. Just take it as a cliff notes version .
Old 11-01-2007, 10:18 AM
dochall22's Avatar
I was pretty sure on the line lock, just didn't know the use of the transbrake. So it's for launching only eh?
Look at my sig and tell me if you think I'd need one or would a footbrake launch be fine?
Old 11-01-2007, 10:42 AM
red83's Avatar
if you can get it to hook-up and can afford it. there is no reason why i wouldnt get one. you do not have to use it all the time. it has no adverse effect on drivability.
if the track sucks. footbrake it. it the track is hooking. use the brake.
with the stall you have i would definitly get one!
Old 11-01-2007, 10:50 AM
dochall22's Avatar
thanks!
