WTF!!!!! Tranny wont shift from 1st
Hello
this is my 3rd time having this problem! The first transmission i had in i had to let off the gas to come out of 1st gear, so i rebuilt it and it worked for 2 days then quit and wouldnt go over 35mph, so i thought its the torque converter so i replaced that and the problem continued. so i bought another trans today put it in and it was riding and shifting gears really nice then it started to take off slugish and then eventually would not go over 35 or 1st gear, but i do have reverse but i always had reverse!!! please if any one has a comment or a solution tell me!!
Oh and the sensor that goes into line block is broken could that cause it?!?!?!?!
thanks
thanks
i dont think it is 3rd i goes to 35mph and by that time the engine is almost over reving but i dont know if i have any codes i do not have a scanner and cant drive the car far because i cant move fast. but i am really getting pissed off because this is the 2nd transmission that has done this so i know it cant be the same thing wrong in both transmissions it might be external like my wireing
the motor is fine it runs good i havent had any problems out of it but like i said the trans will not come out of 1st gear or over 35 mph i checked the transfluid and its good brand new converter but like i said the fliud temp sensor is broken. but i dont know what else to do
LS1Tech Sponsor
Maybe a shorted wiring harness grounding both the shift solenoids? Or maybe a bad PCM its kinda hard to say without a scan tool . I can email you some simple test to see if these solenoids are always turned on. Then at least you would know to back up through the wiring harness and PCM. But is strange to be stuck in first it either has to be commanded or the harness or pcm have to be shorted I would think.
__________________
i had this same problem in when i had my t/a but it only did it for 2 days, then when i took it to a tranny shop we went for a drive and it shifted out harder than it ever has lol it broke the trany mount since then to the time i sold it i worked great
Don't know much about Caprices, or if the 60e in that is the same as an LS1 Fbody??? But I had this same problem with my Jeep Grand Cherokee, and it was a bad speed sensor...Just food for thought. Sensor costs like 20-30 bucks and takes about 5 minutes to replace...
