Yank pt4000 and spray.
Old 11-19-2007, 11:29 AM
zssman's Avatar
Default Yank pt4000 and spray.
Anyone tried this? If so how much of a hit an when? Thinkin of a 100 shot in 2nd or drive. What do u guys think?
Old 11-19-2007, 03:37 PM
Omega Doom's Avatar
this seems to be one of the better combo's around!
Old 11-19-2007, 04:17 PM
Bryan @ Speed Inc.'s Avatar
SS4000 would work better w/ spray.
i think if you kept it to a 100shot then it should be fine... you might blow through it a little though.
Old 11-19-2007, 04:25 PM
SnakesRslow's Avatar
Is the SS series the better for spray?
Old 11-19-2007, 04:39 PM
RedDemonLsX's Avatar
The PE series is for nitrous,ive heard you can spray a 100 shot safely with the PT4000.Contact yank about it though..Mines going in hopefully this week
99Hawk262's Avatar
Yank says to stay away from the PT series if you're gonna spray. I love my PT4400, but if I still had my SS4000 spray would be my next mod!
Old 11-19-2007, 05:23 PM
Black X's Avatar
I spray a 200 on an SS4000. I had to bump my window and rev limiter from where it was at with my ss3600. I shift at 6800 with no problems on the SS4000 and a 200. I originally had the shifts at 6500 and window at 6600 but I had some "blowing through" the window. I now run the window to 7000 and limiter at 7200. It works great.
BE PREPARED TO HANG THE F*CK ON!!!!
Old 11-20-2007, 01:53 PM
zssman's Avatar
thanks.
Old 11-20-2007, 03:58 PM
better than the PT yes.
the PT series converter has got to be one of the best max effort n/a converters for a 4l60e/ls1 combo.
i would think a 100 shot or less would be fine... but you'd probably not see as much of a gain as if you sprayed a 100 shot on an SS converter.
Old 11-20-2007, 04:14 PM
Omega Doom's Avatar
I wonder what's the main difference? whats the difference between a 500rwhp N/A motor and a 500rwp nitrous motor? besides the torque?
Old 11-20-2007, 04:43 PM
Yank would have the best answer for that.
Old 11-20-2007, 05:38 PM
MontereyLS1's Avatar
If you have a PT4000 and 500rwhp, then you're already gonna be blowing through it (probably sitting on the rev limiter) The 4000 stall speed is calculated on a stock Ls1 application. The more power you make the bigger the stall is gonna loosen up, no matter how you make the power.
Old 11-20-2007, 06:12 PM
Omega Doom's Avatar
ok does this rule still apply if you had a 400rwhp car?
Old 11-21-2007, 10:29 AM
Ragtop 99's Avatar
Nitrous often produces much more torque as the full spray is available at lower rpms. For example, a NA motor may make 500 HP at 6500 but peak torque of 450 ft-lbs @ 4800. A nitrous motor could make the same peak HP but 550 ft-lbs @ 4800.
Old 11-21-2007, 10:33 AM
Ragtop 99's Avatar
A PT 4000 is going to work fine a cam or heads & cam car. It pushes through a bit due to the extra power, but most cammed cars make peak HP and torque at higher rpms than stock, so the combination works fine. The extra shift extension leaves the motor closer to peak HP.
Old 11-21-2007, 10:52 AM
Retired Street Racer
Matt D's Avatar
The PT series is built with much more shift extension than the SS series because it was built as a motor converter. The SS is tighter and allows you to spray without blowing through it.
Old 11-21-2007, 11:46 AM
vanilla89's Avatar
How come no one run's the py3600 since it's made for spray that way you dont have to worry about blowing through it
It's the one i have,I plan on spraying a 200
Old 11-22-2007, 09:38 AM
Ragtop 99's Avatar
Originally Posted by vanilla89
How come no one run's the py3600 since it's made for spray that way you dont have to worry about blowing through it.
It is a good converter for 150+ shot. Most people find it a bit tight for NA use if they are mostly going NA with just some spray here or there. It also works nicely behind a stroker motor or mild FI applications.
Old 11-22-2007, 02:02 PM
Omega Doom's Avatar
I have the Yank PE 4200 but it does not show on their site anymore? that does look good for some reason?
Old 11-22-2007, 02:45 PM
NoGamesLS1's Avatar
I think I remember reading somewhere that you can still get it, but its just not on the site anymore
