no o/d, 1-2 solenoid?
my 4l60e suddenly doesn't shift into overdrive anymore. every other gear works great. i ran some codes and got a 1-2 solenoid error code so i'm going to try to replace it. i've rebuilt engines but trannys make me nervous...how difficult is it to swap the solenoid and where exactly is it?
Do you still have first gear? The reason that I ask is because the solenoid that you are looking to replace is used in two gears. First gear and fourth gear.
Here is a break down of the valve body. The solenoids on the right side are shift solenoids. The one you are referring to is the bottom right one.
Solenoid on the bottom right is the A or 1-2 solenoid.
More photo's are in a link in my signature if you need them. Vince
hey thanks a lot for the pictures. i do have first gear, only 4th is missing. the reason i figured on replacing the solenoid was because an error code for the 1-2 solenoid came up during a scan. when i'm driving around 55 or so and downshift to third i can feel the engine brake but if i throw it back in drive there's no difference.
Certainly if the system has stored a DTC for a shift solenoid it is worth replacing.
But, many timws we see a problem in the servo itself. or it could have a cracked accumulator piston as well.
Start with the solenoied and get back to us!
g
g
i used a matco scanner and i believe it was code 82 1-2 solenoid error. i put a vigilante 2800 stall converter on when i put the tranny in about 15,000 miles ago. i've had a computer tune also but i don't think that makes a difference. also, when i do the solenoid i'm going to change the filter. right now i'm using normal fluid but i want to change to royal purple. i know there will still be old fluid in the tranny even after i pull the pan so how would i go about getting it all out? sounds like a dumb question but i thought i'd ask.
LS1Tech Sponsor
__________________
