punchin it from a roll.
Old 05-13-2008, 12:41 PM
Dragkid1917's Avatar
Default punchin it from a roll.
Does anyone else here have an issue when you pull out lets say onto a highway from a light, and you drive it onto the highway, Obviously not under WOT, and as soon as your cars straight in a lane, maybe goin 15 mph you punch it and it just kindof goes at like your converter rpm (mines 3600) and then after it hits like 35 it downshifts to first and takes off like a rocket. No matter what i do the only way i can race full steam from a 20 roll is to downshift it myself. The car just wont downshift at that low of an RPM. Is this just the tuning?
Old 05-13-2008, 03:18 PM
Kingc8r's Avatar
Did you have your car tuned with new shift points?
Old 05-13-2008, 03:37 PM
Elliott's94Z's Avatar
Mine does that but only for a quick second then it launches
Old 05-13-2008, 03:40 PM
humm, yhea like when its supposed to shift at the track, which raises another question of weather the stock tach is accurate which im thinking it isnt. But i belive it was tuned, i rele dont know the full correct answer but i dont see why he wouldnt have tuned that in.
Old 05-13-2008, 04:08 PM
I noticed mine did that after I had my tune from pcmforless..I had Brian tune for "firm shift points" maybe this is why it does this.???
Old 05-13-2008, 04:09 PM
1998Z28LOADED's Avatar
My car does the same thing, there's a small little rpm range where it wont kick down. Im sure they are all like that. If you have the car in D and not OD it will downshift almost at any speed from 2nd or D. Try it out.
Old 05-13-2008, 07:23 PM
z28_YOU_HO's Avatar
mine would do that with the stock stall
Old 05-14-2008, 08:08 AM
humm maybe leaving it in D is the way to go... good call. By the time id need to shift outof D to OD in any race ill be at 120-130 mph anyway...
Old 05-14-2008, 09:33 AM
blitzd247's Avatar
If you are going to manualy shift a 4l6x I would reccomend only shifting from drive to overdrive. I killed a couple of these already. But a good tuner will eliminate the need for you to shift at all.
Old 05-14-2008, 09:53 AM
radz282003's Avatar
This may be way out there, but was your car a 2.73 car before adding your 3.73s? If so, maybe that is part of the problem and you need to have your shift points changed...
