Will i need a stall???
Well i'm putting a cam in my girlfriends 2004 Gto. Will i need a stall?? The cam specs are 224/227 -.563/.569 114 . If so what size??? Not really going to be racing just want to make the car cam only.
yes, you will be able to drive it and it will run just fine. i am running a very similar cam with the stock stall. it runs very well. if you are not into racing, i dont' think i would change the stall. then again, if you are not into racing, i wouldn't change the cam. the only reason i see (if you do not care about racing at all) to get a stall would be so the car doesn't want to push through the brakes when you come to a stop. the car will push a little harder after you raise the idle to accomodate the cam.
