what stall to go with?
Old 05-14-2008, 11:58 PM
MYSTIC-1SC's Avatar
Default what stall to go with?
I have a 2000 camaro with bolt ons, and am ordering 3.73 gears, and would like to know what stall people would recommend to run with this setup.
Old 05-15-2008, 12:04 AM
Kingc8r's Avatar
Interested as well, I'm thinking someone will say do a search though
Old 05-15-2008, 12:15 AM
super_fro_daddy's Avatar
I'm very happy with my PT4000.
Old 05-15-2008, 12:16 AM
LT1-DAN's Avatar
Vig 3200 is Awesome.
Old 05-15-2008, 12:34 AM
Hark_Z's Avatar
I'd look up Edge converters.
Old 05-15-2008, 12:54 AM
MYSTIC-1SC's Avatar
so anywhere between 3200 and 3600 would be a pretty good combination with the current mods i have.
Old 05-15-2008, 01:25 AM
HaulinHawk's Avatar
Runnin a yank ss4000 here,great verter.
Old 05-15-2008, 07:10 AM
Circle-D's Avatar
I would recommend 2 options. Our "2C" is rated about 3200 and is perfect for the casual racer who wants a little more performance, but wants to maintain street-ability. Second option is our "4C". It is rated at 36-3800 and is more performance oriented. Still very drive-able on the street, but will drop you ET by .5, if you can get traction. If you are considering a cam in your near future, I would suggest the "4C".
Chris
Old 05-15-2008, 07:48 AM
TXZ28LS1's Avatar
happy with my VIG3200 stall here!! my car is never gonna see the track and im not out to set records. its a daily driver street car so i wanted something that will feel like stock and drive closest to stock.
Old 05-15-2008, 09:23 AM
Restricted User
Vortech Converters's Avatar
Default Depends on
what your goals for the car are. Like Chris said, 3200 is a great daily driving type converter. It would be good with bolt on's as well. But if your car is going to get heads, cam , intake, TB, etc,etc, Your going to need the looser 3800-4200 range {depents on what the WOT upshift rpms are} to make use of your new found power adders.
Here is a shame-less comercial to consider: I have a 3200 Vigilante that i just rebuilt with a high carbon lock up clutch lining, also new bearings,springs,and rollers that i'd let you have for $350 shipped.
But you really need to have a vision of what you want your vehicle to be. You only want to buy a converter once.
Mike
Old 05-15-2008, 01:15 PM
TORK?'s Avatar
Happy with my SS3800. With that and 3.73's I dropped .7 off my 1/8th mile
Old 05-15-2008, 01:19 PM
tylerdj's Avatar
I will be going with a PTC 3600 and 3.73's.
Old 05-15-2008, 04:39 PM
TA1364's Avatar
Im running a ss4000. I DD it, not bad all
Old 05-15-2008, 07:24 PM
MYSTIC-1SC's Avatar
thanks for the advice. anyone else?
Old 05-16-2008, 09:37 AM
radz282003's Avatar
My brother ran 3.73s and a SS4000. The fastest he ran on a intake and catback was a 12.4 on DRs with mid-1.6s. He ran 12.2s (really easy) with LTs.
I've only run 12.6s with manifolds because of banging into the rev' limiter on 3.23s and a SS3800.
I think you should go at least a 3500. You'll likely find that you'll like it and wish you went higher.
Old 05-17-2008, 09:00 AM
99Hawk262's Avatar
Yank SS3600 or SS4000 are great daily driver converters that offer great performance....if you're planning a cam or H/C down the road without spray, the PT series is King!!
Old 05-17-2008, 10:41 PM
deadcities's Avatar
I'm pretty pleased with my Yank SY3500. Good luck finding one though.
Old 05-18-2008, 09:55 AM
TA1364's Avatar
Heres some results to consider. SS4000 1.63 60' with simple bolt ons and bfg drag radials
Old 05-18-2008, 01:31 PM
Pontiacerator
RevGTO's Avatar
I think the Yank SS3600 is the perfect DD converter for a bolt-on/gears car.
Old 05-18-2008, 07:36 PM
dragcamaro's Avatar
i have a tci street fighter, i see around 3300 i think, its great compared to stock, but if i get a new one ill go with 4000, idk what it is but this stall on the ls1 feels less slippy than the 2500 in my old lt1 car
