help/advice changing a torque converter
I've never had to change a torque converter, I have a good understanding on what needs to be done, and how to do it correctly, but still kinda nervous about doing it myself. I'd rather do it myself than pay someone to do it ya know. I really like to understand exactly what I'm doing before I get my hands dirty. Are there any instructions on the net on how to do this? Thanks for any help or advice that you could offer.
+1 to that modernusclecars.net tutorial, that has a lot of good info
1) If using jackstands make sure you get the car high enough so you can get your extensions up to get at that top bellhousing bolt
2) Take your time and don't rush anything
3) Don't lose those stupid e clips that hold in the transmission cooler lines
+1 on the stupid e clips, I honeslty think that was the hardest thing about the swap was those stupid clips and im pretty sure you have the good year for the torque converter bolts so i dont think you have to worry too much about stripping them but you might wanna heat them up first so you can break through the loctite easier.If you need any help just post it up on here, goodluck with it and be sure to get a trans cooler also
no problems breaking the converter bolts loose. i held the main crank pulley with a socket and hilton popped them loose. easy as cake. no heat required.
I did mine in a 1 car garage on jackstands with a friend and we did it in about 10 hours. It is kind of pain to get to the top bolts but its far from impossible. Just have lots of extensions and patience and its not that bad. If you are mechanically inclined at all do it yourself and save the money. Just take your time and don't get frustrated if you hit a small snag somewhere (probably the e clips)
i agree i did mine on the garage floor and it really wasnt that bad,besides stripping torque converter bolts..its also good to kinda take pride in your work and be like hell yeah i just did that myself and saved 300 or 400 bucks, and the dealers wont sell the e-clips you have to buy the whole housing where the trans lines connects...believe me ive been through it
Swaping stall is a pita if you don't have access to a lift. I recently had my new Vigilante installed by my trans builder/friend, and it took just under 45 minutes including shooting the **** and all... so, it helps a whole lot with a lift and ofcourse someone who knows what they're doing. Good luck.
