Al vs steel pans?
Old 06-06-2008, 12:37 AM
cals400ex's Avatar
Default Al vs steel pans?
is there any benefit of one over the other? how much lighter is the Al pans? i realize the steel may dent instead of crack so that may be an advantage...
Old 06-06-2008, 12:38 AM
LS1Tech Sponsor
performabuilt's Avatar
weight difference in minimal and I prefer the stock pan steel
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-06-2008, 12:52 AM
cals400ex's Avatar
i think i am going to go with an aftermarket pan just for the drain plug. i know i could put one in but you can get some pans for a pretty decent price.
Old 06-06-2008, 06:56 AM
Formulated's Avatar
I like the aluminum pan for the heavy flange and the drain plug. I hate leaks, and the cast aluminum pan is a slam dunk.
Old 06-06-2008, 08:51 AM
big wally 55's Avatar
The aluminum pan will be heavier than the stock stamped steel . The advantage of added fluid and also added strength to the case with a cast aluminum pan is worth the $$$$$$ .
Old 06-06-2008, 09:49 AM
dlove's Avatar
aluminum adds strength to the case but weighs more.
Old 06-06-2008, 10:37 AM
Ragtop 99's Avatar
Get a good Aluminium pan. It transfers heat much better than stock, not to mention increased capacity and a drain plug.
Old 06-07-2008, 01:49 AM
cals400ex's Avatar
i don't really want a pan that hangs lower. Thus, i was going to go with a stock sized pan. if i could find a +1 quart i would consider. i don't want to go with 2 or 3 quarts larger. i don't have a problem going with aluminum if it is better.
