what auto trans for 1xxx hp?
A 400 or a 4l80e would be your best choice. Obviously the 80 is a 4 speed and the 400 will only be a 3 speed. If you you do not mind loosing OD then a TH400 would be a good choice. Make sure to get one with a billet input shaft and a good sprag style direct drum. If we can be of service please give us a call for pricing. Vince
look up rpm transmission. There is a 900hp vette with a rpm tranny down a force fed performance that gets abused everyday and drives and shifts fine until this day and its still a 4l60e
Thanks everyone.
Let me give you a bit of background on my plans. I came from the grand prix world. My race car / daily driver (i was 19 so it doubled for both) was a 95 Grand prix that we swapped the L67 into and built it up to about 300fwhp with stock heads and no IC. I blew up the car, got married etc etc...
Long story short I want to start my next project this winter to be completed by next September. My plan is to take my 99 TA which is currently stock. Use it as a toy for the track. I want to hit 1,000hp on the dyno, but then tune it back for the street since I doubt a 1,000hp car will be reliable enough to drive to work when i want to get there fast But turning the boost down and having it at about 800hp should be fine (screw gas mileage, I'm not building this car for it to have great MPG, that's what the beater is for.
What was interresting about the GP world is that you have 2 or 3 vendors for your part choices, Company A, B or build it yourself.
Now in the LS1 world there's literally hundreds, just looking for some opinions about who can do what. Thanks to all the good info so far.
what did the 4L80 trans come from?
hey SOM
That truck 4L80 trans, isn't that the trans they used with the 6L cast iron block engines too?
so It looks like that is where I should start for my powertrain. get a wrecked 2500, strip it down, build it up bolt it in.
ps an engine swap is technically a bolt on mod in my opinion since there are bolts holding it to the car
im not sure what mods exactlt i just know he has a RPM transmission and a f1 supercharger...
