Automotive News, Media & Press Television | Magazines | Industry News
Autoblog - Ford F150 SVT Raptor 6.2L
Old 05-26-2010, 11:51 PM
TriShield's Avatar
Default Autoblog - Ford F150 SVT Raptor 6.2L
2010 Ford SVT Raptor 6.2 is born to fly
by Rex Roy (RSS feed) on May 25th 2010 at 11:57AM
Unless you're a died-in-the-burlap save-the-planet kind of person, you probably think the 2010 Ford SVT Raptor is freakin' cool. There's not a factory truck on the planet that can wing across the desert floor with equal ease, grace and unmitigated speed.
The 2010 Raptor genuinely has no competition In the world of production trucks, but that doesn't mean it can't be improved. If you bent the ear of the right Ford engineer, he would admit that the 2010 SVT Raptor was supposed to launch with the 6.2-liter SOHC V8 we're testing today. The aging 310-horsepower 5.4-liter Triton mill included at launch was never the perfect fit for the radical Raptor. Too tame.
From the truck's introduction last Fall, everyone knew the all-new iron-block/aluminum-head 6.2-liter engine would be better. But no one knew how much better until now. Read about our wild test drive (and brief flight) after the ummm... jump.
Ford Motor Company invited the press to its Romeo, Michigan proving grounds with the intent to demonstrate that the 2010 SVT Raptor was a more than just an exceptional desert runner (as if that weren't enough). Slogging through narrow, rutted and muddy trails was further proof that the Raptor is plenty comfortable in typical Midwestern off-road environs. Our time at the 3000+ acre site also included the chance to flat-foot the new 6.2-liter V8 to see what 411 horsepower felt like. In a word: good.
But of all the driving we enjoyed, the most entertaining moment was launching the Raptor into the air after completing a high-speed off-road course. One can only imagine the conversations engineers must have had with Ford's legal team to get this event approved.
Engineers: We want the press to drive the Raptor off a ramp so fast that all four wheels leave the ground.
Lawyers: Are you nuts?
Engineers: The truck is designed to be driven that way. We know because we include a large jump at the end of our standard durability loop. Our test trucks have done the cycle thousands of times.
Lawyers: So? It's not the truck we're worried about. We're talking about the press. Half of those guys can't even parallel park. The ones from New York don't even have driver's licenses. You want to let them launch a 6,000-pound truck at some crazy speed? Are you guys nuts?!
Engineers: We'll ride with them.
Lawyers: Okay, you are nuts.
Here's how the experience went down (up?): After exiting a slippery right-hand corner consisting of wet grass and mud, you aimed the truck between two pylons at the top of a gravel ramp. The faster you were going, the higher and farther you'd fly. Following a rainstorm similar to one we've read about in the Bible, a low area just ahead of the ramp was filled with standing water and thick mud. To hit the ramp properly required getting hard on the throttle through the sticky stuff, which did all it could to knock the truck sideways.
Going over the ramp at anything but dead-nuts square virtually assured disaster. Landing on one wheel might cause the Raptor to corkscrew into the ground, instigating an unpleasant, cab-crushing roll.
There would be no blown-out windows today.
With the optional ($3,000) 6.2-liter V8 howling under the Raptor's vented hood, we hit the ramp spot on. The suspension fully compressed and then I heard it ... Wagner's Ride of the Valkyries. Or angels. At that very moment, the wheels hung at the end of the suspension's rebound travel, poised to ease the truck's landing. The truck flew about 20 yards before returning to very terra firma. The landing used all of the suspension travel (11.2-inches front, 12.1-inches rear). And then some. This gallery photo reveals a once-flat front skid plate returned from the jump concave.
The lawyers could breath a collective sigh of relief. Nobody died. Not even the guys from New York.
We've already written extensively about the Raptor's new engine, covering its fitment to the 2011 Ford Super Duty, the high-volume truck the engine was really designed for. Important details include the enlarged, two-valve cylinder heads utilizing a twin-plug design for cleaner combustion, variable timing for the single overhead cams (a total delta of 43° to improve power output), and roller rocker followers (reduces friction). Engineers told us that they considered four-valve heads, but that they'd be too large to fit in the existing F-Series engine bay.
The Raptor gets its own version of the 6.2-liter that uses unique cams with identical lobe profiles, but separates the intake and exhaust valve operation with greater overlap for more power. Additionally, the Raptor's V8 gets an electric radiator fan (compared to a crank-driven unit) and a special premium-fuel engine management program with more aggressive fuel and ignition maps.
These changes result in 411 horsepower compared to 385 hp for the Super Duty. Torque increases to 434 pound-feet from 405 lb-ft. Run on regular fuel, the SVT's rate of work drops to 401 hp with no drop in torque. Compared to the standard 5.4-liter V8's 310 hp and 365 lb-ft torque, the 6.2 provides a huge boost. (Some outlets publish 320-hp and 390 lb-ft torque for the 5.4-liter, but this is generated running E85).
Regardless, who doesn't love another 101 horsepower?
Nearly every suspension component was changed to handle the motor's extra grunt. Engineers tweaked spring rates and the action of the internal bypass Fox dampers to make sure there wasn't undue pitch under the truck's increased power. If the old truck was good for 0-60 mph times in the mid-eight second range, the 6.2-liter should do it about a second less.
As with base Raptors, power runs through a six-speed 6R80 gearbox, shift-on-the-fly transfer case, 4.11 gear set and 9 3/4-inch rear axle. Electronic controls give drivers better command of the truck's hardware, including a sport mode for the stability control system and a special off-road setting. Additionally, the rear axle features electric-locking that operates in 2WD, 4WD High, and 4WD Low. Standard hill descent control works in Drive as well as Reverse, providing a fully automatic "speed control" for safely descending steep grades. All electronic nannies can be de-powered, leaving control totally in the hands (and feet) of the pilot.
Twisting the ignition brings forth a recognizable V8 rumble. The change in cams sexes up the rumpa-rumpa of the idle, although curiously, that more aggressive idle is the only clue that there's a mightier engine under the hood. There are no exterior badges, special exhaust pipes or other identifiers. A minor oversight? We think so. And it's not like the Raptor was designed to fly under the radar in the first place.
At wide-open throttle, the idle burble expands to a roar that reminds aging drivers of a sound from yesteryear: secondaries opening on a four-barrel carburetor. The noise confirms that power is getting to the massive 35-inch BF Goodrich All-Terrain tires that feature proprietary construction developed just for the Raptor. On normal roads, the exhaust and induction noises remain subdued, as does the noise from the BFGs. In the cab, occupants remain comfortable in the deeply contoured buckets that provide more bolstering than regular F-150 seats.
Aside from the extra 101 hp, the 6.2-liter Raptor is nearly identical to the base truck dynamically. On road the suspension is soft, floating over the tarmac – regardless of the condition of the surface – and never feels out of control. The steering isn't Porsche 911 precise or tactile, but it gets the job done with a lightness that belies the truck's three-ton mass. To make too much of these nicks misses the point of the Raptor's design intent. The on-road ride is compromised to enable its off-road capabilities, a trade-off some drivers are eager to make.
If the new 6.2-liter V8 exposes anything about the 2010 SVT Raptor, it's that the truck's chassis could probably handle another 100 horsepower. Or 101. At some point during our drive time, even the big engine felt stressed through the thickest mud at speeds that would make Walker Evans or Rod Hall proud. Perhaps the aftermarket will be quick to offer a supercharger for the 6.2? We think yes.
Whether Saleen or some other tuner steps up to the plate, the reality is that anybody considering the $38,020 base Raptor should cough up another $3,000 for the 6.2-liter engine option. It's a must-have feature with no downsides, a fact born out by Ford's recent announcement that the crew cab version of the 2011 Raptor will only be available with the larger engine.
We wonder if the longer-wheelbase truck will fly as well as the extended cab. And we can't wait to find out.
Old 05-26-2010, 11:57 PM
xXxSilveradoxXx's Avatar
Looks just about like my '89 Silverado upon landing!
Old 05-27-2010, 08:53 AM
violent_celerity's Avatar
Im kind of disappointed with that jump.. those fox shocks need ALOT more compression damping for sure.. ive jumped my 84 higher and further than that, and it was much less dramatic.. and my truck is leaf sprung front and rear with a solid axle up front.
Old 05-28-2010, 12:43 PM
ThisBlood147's Avatar
Saw my first one of these on the road the other day. It was black and had a custom/aftermarket grill on it (no giant FORD lettering).......talk about a tough lookin' ride. I'm not much of a truck guy.....but I'd hit it. Glad to see they finally got the 6.2 model out, I was beginning to wonder what the hold up was.
Old 05-28-2010, 12:47 PM
But is your truck's suspension absorbing as much mass as this Raptor's? Plus the thing looked like it was hauling *** when it made that jump. I'm not claiming to be an expert at offroad truck suspension, but from everything I've read this truck is obviously doing something that no other production truck is doing or has done in the past.
Old 05-28-2010, 12:58 PM
thatguy383's Avatar
yep...this ^^^^^ i saw one the other say, looked way bigger than these, maybe it was lifted already, chick driving it, red and black, and there is an all black one in town here that makes me salivate....
Old 05-29-2010, 02:12 AM
i would have to imagine my truck weighs the same, if not a couple hundred pounds more than a raptor. I will give it that, it was moving right along, but i was doing 75mph when i jumped my truck.
All im saying is that it needs some suspension tuning. on washboards and deep whoops, the new raptor is king. i just wouldn't be jumping it much without some tweaking.
Old 05-29-2010, 06:43 PM
It doesn't matter how much more mass the Raptor is compared to any other truck. I would expect a truck that was designed to drive that way to handle that little jump better.
Old 05-29-2010, 11:38 PM
What bit of information are we basing this "under performance" on exactly? The one pic of it at its most bottomed out? Do you know how fast they were going?......how high the ramp was?.........how steep the jump and landing were? I mean, there's not even a video of the jump and landing. If that truck made that landing and lost very little speed then I think it handled it very well. It's my understanding that an articulated suspension is meant to absorb the impact of landing.......not resist it. From the photo it looks like its doing exactly what its intended to. Now, if they had told us that the truck stuttered and swung around to a halt after that landing (or worse yet, rolled over)......then I'd agree.
Old 05-30-2010, 02:10 PM
CranMaro99's Avatar
Is it just me, or is Ford kicking *** lately? I like.
Old 05-30-2010, 02:14 PM
I'm basing my assumptions on these pictures.
Like I said before, I would think that a truck that was "designed to be driven that way" would have handled it better. I base that on what I said in my first post, I have an '89 K-1500 Z71 that I have jumped numerous times. Judging by the video I've seen of my truck I can safely say that I've got it as high as the Raptor and my Silvy handled it just about the same. It didn't bottom out, clunk, swing, shutter, fall apart or roll over. During the flight my truck was nose heavy but it looks like the Ford also is.
Old 06-01-2010, 08:29 AM
BanditTA's Avatar
Aaa, to expensive. GM was doing it in the mid 90s with ZR2s in several advertisements.
Old 06-01-2010, 11:49 AM
Cole Train's Avatar
GM did good with the ZR2's. I love the Raptors as well though There is a black one locally that i drool over when it goes by
Old 06-04-2010, 04:23 AM
mrx8200's Avatar
Gotta say I don't love the grille, but damn if ford doesn't make some nice trucks.
Quick Reply: Autoblog - Ford F150 SVT Raptor 6.2L
