Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
No brake pressure when car is on?
Old 02-15-2012, 05:51 PM
dr.duct_mossburg's Avatar
Default No brake pressure when car is on?
Yesterday I was driving and lost brake pressure. I wasn't far from home so I drove back home using the engine to brake the car. Once home I got under the car to notice that my passenger tire hose had rotted and was the cause of the problem. Note: I never lost all brake fluid though I did get the check brake fluid light and stability program disengaged.
I went to the local advanced auto and got a new brake line and put it on. This evening I bled the brake caliper (inner bleeder screw first, followed by outer). Though I get good brake pressure when the vehicle is off, I lose it when the vehicle turns on. I have since bled the passenger rear, driver rear and am about to rear bleed the passenger front again, followed by driver front.
Is there something else that I am missing? I read the FAQ but didnt see anything about this. I'm assuming there is still just a little air in the lines and as I finish bleeding than it will firm up? Brake booster adding pressure once the vehicle is turned on?
TIA
Old 02-15-2012, 06:04 PM
RADEoN's Avatar
what does your fluid level look like? is there anything squirting onto your brake booster from your master cylinder?
Old 02-15-2012, 06:15 PM
Fluid is good and now clear (new fluid) no squatting that I can see. I have one more wheel to go but I am not confident that it will be good after this. May just tow it tomorrow.
Old 02-15-2012, 06:56 PM
serik21's Avatar
Abs cars I usually bleed it first with it off then with the car running.
Old 02-15-2012, 07:34 PM
Im bleeding them again right now. Just finished the backs. I started the car a few times the first time around, not going to do it at all now. Luckily, The g.f is being a good sport and pumping the brakes for me lol Guess my Valentines surprise yesterday is paying off today
Old 02-16-2012, 09:49 AM
rjoffe's Avatar
Probably need to do some searching, but I remember an issue where the ABS pump does not fill properly after all fluid is drained.
Old 02-16-2012, 05:27 PM
RADEoN's Avatar
any time you toss your girlfriends salad, she will help you with car stuff.
Old 02-16-2012, 05:50 PM
****, I didnt even take her to dinner. lol Just ordered some pizza to eat in between bleeds (no pun intended), Ha. She knows her place Jk, Shes a good sport.
Old 02-16-2012, 05:52 PM
BTW, I bled all 4 wheels x2 and it was good after that. The pedal was still very low but I gave it a test drive just to see if I could get it to a repair shop and as a drove it got a tad bit better. When I got in the car this morning everything was perfectly good (pressure wise). Thanks for the aid fellas. First time I ever had a PITA brake change.
Old 02-16-2012, 06:01 PM
jmargo's Avatar
Are you in any of the states involving the brake line recall ?
Old 02-16-2012, 11:29 PM
No idea. Im going to replace them all with steel braided in the summer and just be done with it. I have plans to do rotors, pads, lines and fluid all at once.
Old 02-21-2012, 03:08 PM
9t8z28's Avatar
Brake line recall ? What states? Anymore info?
EDIT: Nevermind, I just googled it. Do I have to be under a certain mileage to qualify for this?
Quick Reply: No brake pressure when car is on?
