Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Katech Shifter 5/8-18
Old 10-03-2012, 02:53 PM
shadyLS6's Avatar
Default Katech Shifter 5/8-18
I have been looking for a weighted shift **** for a while. TWM ***** are legit but way to much $$ and all i wanted was the Abrams one.. i found these the other day, I ordered a brass and a steel ****. it was cheap, $19 for both, just missed free shipping. I'll let you know if they are worth the $
http://www.jwwinco.com/products/section4/bk/
Old 10-03-2012, 03:35 PM
RADEoN's Avatar
nice. glad to see a company making nice products and not having to pay out the *** for it to have a brand name on it.
Old 05-08-2013, 10:55 AM
shadyLS6's Avatar
forgot to update this thread, thanks jamesdem for reminding me
cant go wrong for the price. i have the steel one as well painted silver metalic
Attached Thumbnails Katech Shifter 5/8-18-img_4645.jpg
Old 05-08-2013, 11:40 AM
Dmax/04V's Avatar
Looks good, makes a nice difference when driving too depending on the weight there. I will say however that the washer works just as well when its on the underside of the boot.
Old 05-08-2013, 11:44 AM
jamesdem1123's Avatar
I just ordered a brass one. I will be covering it in alcantara/ultrasuede type material and sliding the collar of the boot down so that the shifter is exposed.
Old 05-08-2013, 11:51 AM
Dmax/04V's Avatar
I tried to do this with mine, it does look good. You may want to look into a fitting that can be screwed into the threaded section of the ball so you can stop it where you want without it being able to turn on you. If you just use the katech hardware you will end up having that massive jam nut sitting up for all to see; then again if you don't mind that no worries.
Old 05-08-2013, 11:53 AM
tmonttt's Avatar
I take it that these only work if your shifter is threaded?
Old 05-08-2013, 12:29 PM
FuzzyLog1c's Avatar
Why isn't this thread titled, "Show me your *****?"
Old 05-08-2013, 03:15 PM
ravenls6v's Avatar
So does it match all the other brass in the car?
Old 05-08-2013, 08:14 PM
xbladr's Avatar
There is other brass in your car?
Old 05-08-2013, 08:21 PM
xbladr's Avatar
Do they have them in an m12x1.25 threading? Also what is the weight on the ball im using a gt500 **** and wouldnt mind if it was heavier
Old 05-08-2013, 08:54 PM
ravenls6v's Avatar
None...
Old 05-09-2013, 01:48 AM
xbladr's Avatar
Originally Posted by ravenls6v
None...
Ahhh sarcasm... doesn't always come across on the forums
Old 05-10-2013, 04:29 PM
shadyLS6's Avatar
weighs alittle bit more than a 1lb.. great quality
Old 05-15-2013, 10:33 PM
xbladr's Avatar
Shady after a couple days of going back and forth with JWWINCO I was able to get them to agree to make a **** for me in steel same 1lb weight with my m12x1.25 pattern. Unfortunately it is going to run me $25 for the custom tapping and one of piece they need to make. It is a much better price than going with the abram though so, I am excited. I will post up pics when I get it installed.
Old 06-02-2013, 11:24 AM
s-cam's Avatar
I am looking at the steel one and possibly painting it . Question I have is how bad does the heat transfer through the shifter ball? How hot does it get?
Old 06-05-2013, 12:25 PM
ryridesmotox's Avatar
I had an exposed TWM weighted ball in my last car... Heat transfer wasn't the problem for me... It was the sun shining on the damn thing through the window when it was parked lol... It would get hot from that. It really wasn't bad though. It also got cold in the winter when the ambient temps dropped. The V shifter doesn't go straight into the transmission case like an f-body. There is an extended linkage apparently. So like my last car, transmission heat isn't really going to effectively transfer like it would if you had the stick coming right out of the trans.
Old 06-05-2013, 12:29 PM
shadyLS6's Avatar
agreed /\ the sun is the biggest cuplirt
i painted mine but didnt clear coat it..bad move, got sticky and ruined the finish with my palm... need to redo it.. poast up when you get you custom one on
Old 06-05-2013, 12:34 PM
Hey shady, is the thread and pitch the same on the stock shifter as it is on your Katech short throw? I kinda like the look of that brass testsicle you shift with... I want to rub one as well lolol... Seriously though it looks pretty sweet, I want one.
Old 06-05-2013, 01:10 PM
DACTARI's Avatar
Does the carpet match the ball?
Quick Reply: Katech Shifter 5/8-18
