Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Need help finding Header install thread
Old 07-12-2013, 06:34 PM
manitzchris's Avatar
Default Need help finding Header install thread
Hi i tried using the search to find header install but no luck. Im about to install my headers tonight, can someone hook me up with an install and with tips.
Old 07-12-2013, 06:35 PM
also i have kooks 1 3/4 will these mate up to my stock exhaust fine?
Old 07-12-2013, 06:40 PM
ravenls6v's Avatar
http://marylandspeed.com/kooks-conne...fo-p-2103.html
or...
http://marylandspeed.com/kooks-conne...fc-p-2102.html
Old 07-12-2013, 06:46 PM
ravenls6v's Avatar
https://www.google.com/search?q=cts+...rp.hil1vMqPKKE
Old 07-12-2013, 06:53 PM
OneSlowV's Avatar
Just remove plug and wires first also have to unbolt steering rod to put new headers in place.
Old 07-12-2013, 07:02 PM
ravenls6v's Avatar
Originally Posted by OneSlowV
...also have to unbolt steering rod to put new headers in place.
Maybe with pacesetters...you shouldn't have to with kooks
Old 07-12-2013, 07:20 PM
rwarden90's Avatar
Go to cadillacfaq.com thats where I got my refrence its for a bb header set but that makes no diffrence
Old 07-12-2013, 07:28 PM
jamesdem1123's Avatar
Make sure you have the car jacked up plenty
Old 07-12-2013, 08:08 PM
Stone17's Avatar
Where do you live at?
I live out in Sugar Land.
Header are easy to install.
Remove the bolt with a ratchet wrench.
Remove oil dip stick and steering shaft.
The header drop out of the bottom of the car.
Old 07-12-2013, 09:03 PM
i live near hwy 6 and bellaire
update: 2 hours into the install removed the spark plug wires and started taking the headers bolts off 2 snapped on the driver side using little force. Still working on the passenger side. the car is a 05 cts-v with 101k miles
Old 07-12-2013, 10:18 PM
54inches's Avatar
Holy ****. 2 already snapped? Cold engine? Did you use any penetrant? Did you get them out?
Old 07-13-2013, 12:00 AM
warm engine and yes i did use pb blaster. no i didnt get them out they were both of the nuts on the end of each side of the header
Old 07-13-2013, 12:10 AM
OneSlowV's Avatar
Damn 100k car bet them dudes are in there good
Old 07-13-2013, 12:13 AM
okay this is confusing if this is the stock headers and cat where does the kooks and the catless connector pipe go?? it looks way to long
Attached Thumbnails Need help finding Header install thread-20130713_001049.jpg
Old 07-13-2013, 12:49 AM
odthetruth's Avatar
You may need to cut and weld. I know the pacesetters with the offroad connectors went on perfect, and although they looked larger, they lined up with no issues, basically perfect.
Old 07-13-2013, 10:19 AM
Finished install last night, currently at the muffler shop to cut and weld the stock exhaust
is having some problems
-service airbag light is on
-none of the steering controls works
Old 07-14-2013, 10:03 AM
Stone17's Avatar
When you disconnect the steering shaft, Did you spin the steering wheel? That will break the clock spring.
Check the fuse box under the rear seat.
Old 07-14-2013, 10:10 AM
Stone17's Avatar
i live near hwy 6 and Bellaire
I live off 59 and hwy 6. Not far at all.
Old 07-15-2013, 09:15 AM
Damn it I did soon it a couple of times I guess the clock sitting is broken.
How easy is it to fix
Old 07-15-2013, 09:24 AM
Stone17's Avatar
That part cost about $150.
Here a install instructions.
It's on page 181
https://docs.google.com/file/d/0B_xx...it?usp=sharing
Quick Reply: Need help finding Header install thread
