will a Fbody water pump fit.....
....on our cts-v's? looking around it seems like all ls motors have the same water pump, the only thing I am worried about is clearance issues with the width of the pulley itself, and hitting the radiator fans...here is a pic of the difference
CTS-V
F-body
anyone know if it will fit?
CTS-V
F-body
The accessories are in different locations but all that has an effect on is the belt length. The Y-car nominal belt length is ~80.75 inches or so.
CTS-V
F-body
CTS-V
F-body
Btw are you upgrading to a electric or you just need a replacement .
If you run into clearance issues you could probably take the fat pulley off the F-body water pump and put your skinnier V pulley on.
Do you have a spare F-body water pump sitting around, why not just get a vette/V specific water pump?
