13.39 @ 106mph 2005 V
2.06 60 ft. Not bad for first time down the track. Would have went faster without the wheel hop at top of first and bottom of second.
Put the car in competition mode each time but for some reason the wheel hop on the one-two shift was causing the car to just stop accelerating completely for almost a full second. Anyone know what this is? I thought comp mode turned off all the safety stuff??
Without the car dying at the bottom of second it would have went an easy 13.0.
Competition mode just gives you a little more freedom. It shouldn't bog you down though as the TC is off. The only way to turn everything off is to hold the button down for 7 or 8 seconds.
That has to be it as there was still definetly something killing the power when it sensed the wheel hop or the car kicking sideways. What a nooob I am. The car nosed over for almost a full second before kicking back in. Woulda had a killer time to post in the heat too!
The only way to keep it from wheel hoping off the line was a revving 2000-3500 clutch slip. Dumping the clutch was just a waste.
Tire prep was 25 psi, no burnout.
Scary to think what it would do with an axle, drag radial and tune.
Your diff's days are numbered if you are track launching and hopping the diff so hard that you lose forward momentum (due to computer pulling timing, etc.). If you plan to go to the strip again (I mean, even once) you need to get the $550 GForce axles. They completely eliminated wheelhop for me.
These cars are not drag cars, which you will find out very soon if you continue running hard at the track without some precautions. It would be very embarrassing to have to get towed off the track on a flatbed...
Did you notice if the "stability control" message showed on the radio screen? Competitive Driving Mode turns off T/C but stab control is still partially active. In order to fully turn everything off, you need to hold down T/C button for 5 seconds and goes into another mode (forgot the name). May not be the problem though, as the Stab. Control seems to only kick on if you start spinning the rear around a corner (fishtail), for instance. I'm not sure if there's a "diff safeguard" as mentioned above, but if there is, may or may not be a good thing...
I've had the stability system kick in on 3rd and 4th gear shifts down the track due to wheel hop/car getting sideways. I hardly felt the car lose throttle response though. I remember making a pass with TC on and that's when I felt the throttle bog down.
Winner winner chicken dinner. Nothing came on the Nav screen. Thought it was like fuel cut back in the DSM days. Just keep my foot floored and its like someone connected the battery cable and the car took off. Cost me alot of forward momentum. Again, this was as soon as I hit second without /ever lifting off gas. Never did this on street before so I was like WTF.
everytime i see you post this the V crowd takes a good step backwards. let people do what ever they want with their own vehicles without you saying what they should or should not do with it.
to the op, good time. gets you thinking what the car would run with a decent 60'
I merely thought to give the OP some helpful advice, since I have never seen him post before and thought that maybe he is new to the V world and doesn't know of the problems that a lot of V owners (who drive the car in a way that is known to cause many failures) have. He can choose for himself to take my advice, or not.
I'm not sure what I have done to you to make you always pissed at everything I post, but just relax. You only take my posts as negative, when in reality that is the opposite of what I mean by them.
Good track time. But...I gotta say it...
