Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Ground Control...... ?
Old 05-03-2011, 04:39 PM
wcryan's Avatar
Default Ground Control...... ?
so I installed my kit went and drove it around and there is still a little thump in the passenger rear, even after I added a washer. The Drivers left, no matter how big the hole I hit is, doesnt even make a sound.
Any Ideas?
Old 05-03-2011, 11:15 PM
rocket2ya's Avatar
my eibach kit makes all sorts of noises, thought it was because of loose bolts by i torqued the **** out of them and it still makes thuds, squeaks and creaks lol
Old 05-04-2011, 04:03 AM
wcryan's Avatar
it's wierd though, how the drivers side is perfectly fine over any bump, bu the drivers side rear makes a thump even after adding a washer...... dumbfounded
Old 05-04-2011, 01:03 PM
tweeter81's Avatar
I would just add more washers (as many as you can and still be able to tighten the top shock nut properly).
Old 05-04-2011, 01:26 PM
wcryan's Avatar
on top of the shock?
Old 05-04-2011, 05:52 PM
tweeter81's Avatar
Yes, I think that is where you are supposed to add them. Last time I had some suspension work done I had my local shop add the washers for me. I'm almost sure they just added them to the top, but they didn't add enough because the clunk went down some, but not completely.
Old 05-04-2011, 07:29 PM
wcryan's Avatar
so you had them add more and the clunk went away?
Old 05-04-2011, 07:52 PM
adanieljohnson1's Avatar
So do you'll have a lot of creeking noises from lowering? I want to make sure that it sounds and drives like normal when I do this in July!
Old 05-04-2011, 07:54 PM
wcryan's Avatar
just grease the top and bottom of the shock a little.... then you should be fine. Overall it's a pretty good kit for the price. Oh and dont forget to put washers in too
Old 05-04-2011, 09:57 PM
tweeter81's Avatar
No, not yet. That was only a couple of weeks ago. Next time I happen to have my rear seat out (which probably won't be for a long time) I'll just add more of the washers myself.
Old 05-07-2011, 01:18 AM
ferny's Avatar
i went with the mm spacers instead of what gc provides...got an extra set if u need them
Old 05-07-2011, 04:24 PM
wcryan's Avatar
Extra set of what?
Old 05-08-2011, 02:23 PM
Cadzilla's Avatar
It's metal on metal, it's gonna clunk. I found that a thin neoprene washer between the other washers on the back, especially on the top, helped quiet it down.
The fronts on mine don't clunk but when there is extreme angles such as pulling into a steep driveway there's a nasty metal rub click thunk type noise
The bottom line is this: if you're buying a gc kit hoping that it will be quiet as stock, you are going to be disappointed. It won't be, period. There's thick rubber at the top and bottom of the stock springs for a reason.
The kit is a clunky but it makes the car look great.
I'm hoping that when I put on my qa1s that the rear clunk subsides. I may get some helper springs for the front to minimize the unload on driveways etc..
Old 05-09-2011, 12:11 AM
ferny's Avatar
extra set of mm spacers
Quick Reply: Ground Control...... ?
