Hurst shifter for the 2004-2007 CTS-V.
#85
I need to order the bushings to clean up the slop. Also how do I keep the **** from spinning on me and keep it so its lined up right? The shaft has alot of tread on it.
Installed mine yesterday and love it.
#86
BTW, I was able to use a set of those stock shifter ball bushings to tighen up my friends shifter. I just shaved a hair off the end of one and then put back together (didn't take hardly any). Took all the vertical slop out. I greased it up and it feels awesome now so thanks for hooking me up with those.
#87
and i would be in on a group buy for the boot!
#89
I can't say enough for the service Brian provides... He send me a shifter package to Canada with free shipping which is awesome. The first one he sent out got returned to him because Canada post is morons and said my address could not be found. The address was my work which is a well know auto repair facility here. He sent me another one out before he even received the original one back! I received it yesterday and put it in last night.
I had a homemade short throw in my car from the previous owner. It was a stock shifter with a bushing welded to the bottom. I didn't think it was too bad until I installed this one! It's a world of difference. Seems the gears almost find themselves now. No extra cabin noise or vibrations. In conjunction with the ls7 clutch I can pull off some super fast shifts. The feeling is amazing. This weekend I'll be installing revshift blue motor mounts and creative steel transmission mount. Can't wait to see how it works then.
Thanks Brian!
Thanks Brian!
#90
I'm down on group buy brian. I'm in and out on forum so no matter what count me in haha.
And the **** you adjust to your desired viewing angle. Grab a 9/16 wrench and tighten the nut backwards into the ball. Bam. I've never spun a ****. Easy
#94
I may want to get in on this one of these days. Has anybody confimed no issues with Hurst fitment and Creative Steel trans mount?
I'm glad those pivot ball housings worked out.
#95
Do you have the bushings to fix the play in the shifter when in gear? Love this shifter but now hate reverse because its hard to get into now. Just need to do the fix that I saw someone post about.
#97
Group buy for Alcantara shifter boots. Please let me know whether you want standard height or 1.5" shorter.
https://ls1tech.com/forums/cadillac-...l#post18195619
