Giving up finally taking it to a shop
Chirp Chirp Chirp cant find the noise..dropping it off to champion auto in killeen texas
Just a recap i changed the harmonic dampener water pump idler pulley/ assembly
ac belt is off so its not that all that is left is the alternator and the power steering pump. My unit is going to the field for a month so hopefully it gets fixed before then
please lsx gods hear my plea
Turns out when i replaced the harmonic balancer i did no know the bolts were one time use and the same bad bolt has been causing it to chirp i feel dumb :/
just curious. how would it fail?
Its good you caught it before it was was the cause of some catastrophic failure. I'm in the same camp as bmylez upgrade the fasteners if you decide to do work. It makes the most sense.
