KW V3 Coilover rear mounts?
I picked up some KW V3 coilovers for my 06 V recently. What mounts are being used on the rear? Are these bolt in and go to alignment shop? I have not been home to see them yet, but want to be sure to have the parts ready of the install when I get home.
I ask because I recall seeing some threads mentioning rear mounts, and now am either not finding them or am completely mistaken.
Post some pix when you're done. Not too many KW drop pix out here. G/L
the KW do not come with upper mounts both front or rear. you need to reuse stock units.
all other coilovers only come with upper rears and the stock front must be reused.
hint: get banski spherical mounts for the rear instead of reusing the junk stock equipment.
i don't think they have a part number or have it listed on the website, but they do sell them.
https://www.banskimotorsports.com/
I have the Banski rear mounts, but I don't think there's really any need for them. Other than adding quite a bit of NVH I don't perceive any difference in how the suspension behaves.
What "front mounts" are you looking for? If you're trying to assemble everything off the car and then just swap out the whole assembly, then you would need the entire aluminum upper mount/control arm mount:
I think it comes with the upper control arm, and the whole thing is ~$235 per side. The rubber isolator appears to be available separately for ~$45 each, and then another $55 per side for the big dished washer and upper nut. If you want all that stuff, your best bet would be to peruse Ebay - I know I've seen complete strut assemblies for sale. You could also try car-part.com.
mounts
do you mean the rears? I ordered them just to have them in case I want to use them. Depends on what my stock stuff looks like upon removal.
so the fronts dont have any bearings? I guess I just need to get home and take it apart to figure out what I need.
Sorry, I misunderstood your comment about the rubber and washers. The Banski mounts are the rears, and those are the steel and Delrin ones.
I agree that hundreds of dollars for new front parts (which are just rubber and washers) is awfully steep. There's no bearing in the top mount itself - everything's in the picture I posted above.
