steering rack failure
The seals in my steering rack have failed. Here is a pic where I cleaned the area for inspection:
Take notice of the lower control arm. I sprayed it with brake cleaner - driver side.
Here is driving it 20 miles after just one day. The power steering fluid is weeping through the bellows boot wrapped around the inner tie rod.
The leak is coming from the seals where the inner tie rod fastens into the rack. I searched the forums here and elsewhere (and some help) and I noticed this is not an isolated occurrence. There is some confusion where to source another rack - many choices. It seems getting a brand new OEM replacement is not only expensive but also difficult to source. The refurbished units come in a variety where you could end up with something that doesn't fit or encountering the same leak soon after install.
I contacted Turn One and spoke with Jeff and discussed my options. Basically, they rebuild a lot of steering racks. He quoted me $200 for the entire service and includes dyno testing - they also use all OEM parts/seals. I was puzzled why my steering rack took a dump and he explained he was familiar with the cts-v and explained the steering pump produces excessive heat and is a root cause. It breaks down the seals over time and the cooler is insufficient for maintaining a safe operating threshold esp for sporting events.
Anyways, to avoid getting a wrong part or a 'lemon' replacement, I decided to have the steering rack rebuilt. It is not a quick turnaround time - 3-4 weeks as they have high volume this time of year when sporting events are over and everyone is scrambling to replace/rebuild components. Instead of replacing the steering pump, I'm installing a bigger Fluidyne power steering cooler and replacing all the weeping lines.
Just thought I would pass it along - thoughts/comments are welcome.
Thanks!
Thanks!
The word I got is there are many defective racks out there for sale branded as refurbished with bad parts/workmanship etc. I'm not risking getting a loose rack or rupturing another seal.
Given the vendor information that Philistine received and the number of people that have had similar problems, it sounds like the seals are failing under normal street conditions (with the caveat that "normal" varies greatly from driver to driver). The vendor indicated that he thought the problem was with the power steering pump alone, but I personally suspect that the abnormally high temperatures are partly the fault of the poor cooling capability of the OEM cooler.
I think cold also has something to do with premature pump life which in turn affects the racks. I used to also have pretty bad "groaning", etc in really cold temps. Others have reported similar experiences. The "good" thing is these rebuilt racks aren't THAT expensive unless you need to replace your whole damn cradle like I did...
The leak went unnoticed until I have a tear in the boot.
The seals were completely shot on both sides. The passenger side boot was completely filled but the boot wasn't torn so it didn't leak.
Removed the inner tie rods and cleaned it up a bit to get ready to ship to Turn One.
Here is the part number that came out of the car.
Some replacement racks have different features with the threaded penetrations. Here is a close up.
Top - replacement ps cooler. Bottom - OEM ps cooler.
Fuzzy-L found that on ebay awhile ago and a few snatched them up. They are still available.
http://www.ebay.com/itm/Genuine-Fluidyne-EXTRA-Heavy-Duty-V8-Towing-RV-Automatic-Transmission-Cooler-New-/221244228976?pt=Motors_Car_Truck_Parts_Accessories&hash=item33832f0570&vxp=mtr
But yeah, I did consider it but want some expert eyeballs on it.
I ignored all the symptoms of my power steering system having trouble. With just a cap full less than full, it would make horrible noises - like an exhaust pipe huggin' the chassis. Then during competitions, I would add a lot of power steering fluid - constantly topping it off.
I purchased the cooler awhile ago, just putting it off for other stuff. Now, well...I have no choice. I put mods > maintenance...lesson learned. I'm now looking at a getting my rack rebuilt, replacing my ps pump, new inner/outer tie rods, and new ps lines. All that and then of course an alignment - no hp gains with this crap, just headache.
Yep, the cooler I installed is a little different than the Cadillac faq's but the one in the faq's has been discontinued - there are minor differences but pretty much the same.
Here you go:
http://www.cadillacfaq.com/faq/answers/steeringcooler/
Here you go:
