Intercooler blackout query
I believe in blacking it out. Only problem is changing its thermal dispersing abilities. So basically the only proper way to do it I would think would be anodize it. Paint, or ceramic, or powder coating would all act like a blanket and the cooler would become less efficient.
I guess my answer would be no, unless anodizing.
http://www.qats.com/cms/2010/11/09/h...e-part-1-of-2/
But after that video, the difference with airflow was negligible. And with out air flow that is a duh moment. It is widely known black surfaces will radiate heat better, so of course the test temps will be better.
So I don't know, maybe it would help some for a short time off the hit, but past that it made no difference.
I maintain that anodizing is the proper way to do this, but painting it (lightly*) will obviously not hurt it either.
At any rate the OP's question I feel has been answered
I don't think that you can anodize that as a unit.
Are the joints welded or silver soldered?
As an assembly, it may not hold up to the hot
etch tank they drop them to clean them.
Ano would be the proper & professional way
to go though.
Many thanks fofr all of the suggestions & info.
to go though.
