PCM-VATS relearn
PCM-VATS relearn
As I'm going back stock from a maggie/cam/headers combo, I figured it would be easier to find a stock V1 PCM, install it and do the VATS relearn procedure outlined in the link below instead of going to the trouble of sending the tuned PCM out for a reflash.
https://ls1tech.com/forums/pcm-diagn...procedure.html
When I first started on the procedure, it would take 8 to 10 minutes for the security light to go off but after the 3rd leg of the procedure the light goes off within a few seconds of turning the key on when all the other dinging and donging stops...this is how it works on my stock 05 so I figure the PCM has relearned but the car still won't start with that PCM in it. I installerd the tuned PCM from the maggie build that I know the car recognizes and it fired right up...
I checked all the grounds blah blah blah and all that was good. Unfortunately, I don't have a scanner, hand held or any other device to see what the car is thinking.
What am I missing here.
Thanks in advance!
PS..the car has a Kennwood 890 in it instead of the stock NAV unit so I don't have the DIC functions....
Thanks in advance!
There's a dealer close by, I'll see what they can do for me
http://www.ebay.com/itm/CTS-V-2004-E...FWG-UA&vxp=mtr
That's what I get for trying to save a few bucks!!!
Searching all the easily accessed and known people/shops around me yielded nobody that gave me a warm fuzzy feeling about easily pulling the VIN swap off. One guy wanted the car with the computer in it which meant towing, the service writer at the dealer seemed totally clueless and everyone just flat out said they couldn't do it. I wound up buying one from the ebay supplier above and will have it delivered to my door for $99. Seems reasonable for the amount of effort it required out of me...
