Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
engine cutting out at 6000rpms on nitrous
Old 08-26-2012, 07:13 PM
b_evans06's Avatar
Default engine cutting out at 6000rpms on nitrous
Here's the setup:
cammed 6.0 with a carb. Nitrous plugs are an ngk br7ef. Wide open throttle switch spraying from 4000-6500. The setup does have a fuel pressure cutoff switch set at 5psi. Mallory 140 pump split with 2 regulators. Motor set on 8psi and nitrous set at 6 psi pressure. No pressure drop. Rev limiter at 7000. 150 shot on a plate kit with 8* of timing pulled in the msd box with a mix of 93 and 116.
The last 2 times it has been to the track it runs fine on all motor passes. When I spray it it cuts out the top of 2nd and 3rd it pops and the engine and nitrous cuts out at 6000 rpms. Pops out the exhaust which can be heard back at the starting line.
2 months ago I took it to the track and it ran flawlessly. The only change to the setup is a higher gear ratio. Everything else is exactly the same. Could it be cam/crank sensor maybe a bad msd box? It is not just the nitrous cutting out, it is both the nitrous and engine. It seems ignition related not fuel related.
Old 08-26-2012, 10:09 PM
The stunningman's Avatar
If the plugs are gapped correctly. My guess is its voltage. Check your battery voltage put a full charge to it and make a pass. When your at the track constantly cranking it and cutting it off, fans, electric fuel pump, water pump any other electronics will be draining the battery and the few minutes you run it can be insuficient to recharge it fully. The solenoids even though the wires are small pull a bit of current.
Old 08-27-2012, 12:44 AM
Shinsetsu's Avatar
That your car?
Old 08-27-2012, 09:28 AM
b_evans06's Avatar
No my car is gray. It was at Newport yesterday tho with it.
Old 08-27-2012, 09:36 AM
Shinsetsu's Avatar
Cool next time you go to Newport give me a shout on here
Old 09-06-2012, 01:08 PM
Old School Heavy
speedtigger's Avatar
What jets are you running?
Old 09-06-2012, 11:34 PM
Shinsetsu's Avatar
The car was stolen and it was recovered stripped.
Old 09-07-2012, 08:12 AM
89gmcs15's Avatar
Wow. All I can say is wow...
Quick Reply: engine cutting out at 6000rpms on nitrous
