Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
5.3 swap s10 throttle cable
Old 01-15-2014, 09:23 PM
bears416's Avatar
Default 5.3 swap s10 throttle cable
What throttle cable are s10 swap guys using my stock 2.5 4 cyl cable won't work any inputs great
Old 01-15-2014, 10:11 PM
89gmcs15's Avatar
I used my stock cable. Made a bracket for it and it works like a champ
Old 01-16-2014, 03:22 AM
In-Zane Moderator
ZONES89RS's Avatar
I looked at the 2.8 cable on my 92.i think it's gonna work fine.
Old 01-16-2014, 07:24 AM
snook's Avatar
Stock here too on my 85. It was a 2.8
Old 01-16-2014, 01:24 PM
NoSloZ_1's Avatar
2.8 cable on mine as well
Old 01-16-2014, 02:06 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, looks like my 2.8 cable will work. Lol
Old 01-16-2014, 02:49 PM
tylrhmmtt04's Avatar
I plan to use my 2.8 cable also
Old 01-16-2014, 06:05 PM
bears416's Avatar
will that accept the regular sbc throttle bracket
Old 01-16-2014, 07:44 PM
In-Zane Moderator
ZONES89RS's Avatar
Looks like it.
Old 01-19-2014, 09:13 AM
bears416's Avatar
On the msd 6010 shud the pink revHI wire be getting 12v constant even wen the blue revLO is active with 12v or how shud this be wired
Old 01-19-2014, 12:01 PM
In-Zane Moderator
ZONES89RS's Avatar
Just fallow the directions. The rev low is not needed unless you want to use it for burnout or Trans brake. Ect
Old 01-19-2014, 08:13 PM
bears416's Avatar
Doesn't.say anything about not needing 12v cut so I'm assuming it stays 12v constant. Do you guys for see any bogging issues launching off 2 step at 2000 or 2100 rpm on the footbrake
Old 01-19-2014, 09:15 PM
In-Zane Moderator
ZONES89RS's Avatar
The 12 volts to the box is only applied when you want it to run.
That low of an RPM, it's hard to say. You will just have to experiment.
Quick Reply: 5.3 swap s10 throttle cable
