Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Neanderthal Carb Guy BS Thread
Old 03-15-2017, 11:52 AM
  #1461
TTur1996's Avatar
Wow man your shop looks way bigger than mine and its the same size. Now I really wish I would have gone steel all the way. We actually got a 4 post givin to us. And man it was like if it's free it's for me. But after getting it back to the shop I was amazed on how much room it took up over the 2 post. I ended up giving it to a good friend. Definitely getting another 2 post. And your right. We need to add on badly too. Don't seem to ever have enough room. Lol
Old 03-16-2017, 01:52 AM
  #1462
In-Zane Moderator
ZONES89RS's Avatar
Yes sir! So much I have to do it isn't even funny. I don't even know to know how much it will cost in the end.
Old 03-23-2017, 09:51 PM
  #1463
thirdgenbum's Avatar
was commissioned was do a steering shaft for an 80's gm truck to eliminate the rag joint. found a shaft that works perfect that isn't the ugly jeep shaft and viola, here it is. as you can see the truck shafts are on the left and they're a good bit longer than the f-body shafts i typically do which are on the right.
and installed
then monday a friend and fellow mullet militia member brought his 87 gta over for some sfc's
the red car i work on a lot is coming back over tomorrow. it's gonna get a 10 point cage and a rewire, among a few over things. always busy! lol
Old 03-24-2017, 07:58 AM
  #1464
Old School Heavy
speedtigger's Avatar
Matt, can you feel the difference in the way a 3rd gen drives after you put in the frame connectors? I had a 2nd gen, and it was really noticeable.
Old 03-24-2017, 09:46 AM
  #1465
it's a huge difference. it's the number 1 mod i recommend to anyone who just bought a thirdgen. the number 2 mod is rear lca relocation brackets to fix the suspension geometry.
Old 03-24-2017, 12:55 PM
  #1466
Old School Heavy
One of my friends did a build on a 3rd gen back in 2000. The car was a high mile survivor, but it was pretty nice.
When our tech brought it in to the shop, all the panels and doors needed adjusted and it looked ragged out. She put it on our digital frame machine, and even though it had never been wrecked, it was pretty far out of spec..
She pulled it back into perfect specs and then welded the frame connectors in while it was on the machine. When she put it back on the ground, all the panels lined up and it looked amazing.
Old 03-24-2017, 02:18 PM
  #1467
In-Zane Moderator
ZONES89RS's Avatar
Matt putting in work!
Amazing how many 82-2002 F car guys build a car and don't have the relocation brackets.
Old 03-25-2017, 05:25 AM
  #1468
if i had the equipment to do it this way, i most certainly would.
Old 03-25-2017, 07:02 AM
  #1469
Doug G's Avatar
Supposed to be 70 here today, I really hope to "test" the new trans some on a back road or three
Just my few drives around the block don't tell me what I'm looking for...
Old 03-25-2017, 07:20 AM
  #1470
got to. i don't want to live under a mountain of student loan debt the rest of my life.
Old 03-25-2017, 10:14 AM
  #1471
In-Zane Moderator
ZONES89RS's Avatar
Ah, yes. Forgot about that. I'm just trying to pay off my house and what couple small other insignificant loans I have. Don't think I have much left for credit card debt either.
Old 03-25-2017, 04:38 PM
  #1472
Doug G's Avatar
Well....feels damn good....until you throw a belt at 7000+ and you over heat puking anti-freeze everywhere.
Anywho, gotta fix the tossing of my belt.
500rpm drops on the shift best I could tell by eye....data logger is only hooked up to AFR gauge for now.
Old 03-28-2017, 04:33 AM
  #1473
Doug G's Avatar
Default coil relocation ?
Any DIY ideas ????
Post up a pic and a fix...........
Old 03-28-2017, 05:26 AM
  #1474
i'd like to see a picture of your existing belt routing.
Old 03-28-2017, 05:38 AM
  #1475
GC99TA's Avatar
Factory or manual tensioner? I run a Katech manual on the Camaro and a Speed Inc manual on the TA. 7k+ shifts without issues.
Old 03-28-2017, 10:30 AM
  #1476
TXsilverado's Avatar
borrow or buy a pulley alignment tool. I use this one.
https://www.summitracing.com/parts/DAC-93874
Old 03-28-2017, 04:02 PM
  #1477
Doug G's Avatar
Old 03-28-2017, 04:35 PM
  #1478
Bowtiedford's Avatar
Hey Steve, up and running. Same motor that was FI and it's amazing how much smoother it is now with a carb. Powerglide also is in. Just small things now but it is running
Old 03-28-2017, 06:41 PM
  #1479
I've run my belt exactly like that in the past and never had a problem. how's the tensioner?
Old 03-29-2017, 04:43 AM
  #1480
Doug G's Avatar
Tensioner is new and manual ICT part.
I think I found an issue... alt was aligned with crank, tensioner aligned with crank...but tensioner wasn't inline with the alt. Got it inline within .100 I guess....needs another "test"
Quick Reply: Neanderthal Carb Guy BS Thread
