Carb lsx fuel system.
I have a 99 v6 camaro, looking to do a carbed ls swap, has anyone done this? How did you run your fuel system, and can I use my stock fuel lines?
I got a 99 z28 that I went carbed with and I am running the stock 3/8 feed line but ran a new 1/2 return line and put a new fitting in the top of the tank and I am using the stock in tank pump u need a regulator to take the fuel pressure down to 6-7 psi to don't member what brand I have off hand
I did the same with my car. i installed the t block off of a ls1 fuel line for the return. so its exactly like a factory v8 ls1 car, then i used the factory 3/8 fuel line and using the connector mentioned above that snaps in to the factory fuel line ran 6an braided hose to my fuel pressure regulator blocked off the return on the regulator and ran my fuel line to the carb. I am also still using the upgraded efi in-tank fuel pump regulated down to 7psi
