98 ls1 camaro build
98 ls1 camaro build
ok so im going to give you guys the run down of my build and see why you think im so low on hp numbers
98 ls1 m6, 144k miles
stock ls6/2 243 heads dressed by brain tooley racing
custom grind cam
pacesetter long tubes
weiand aluminum intake bored to 80mm
411 pcm swap
ls2 timing chain
ported ls6 oil pump
true dual 3 inch exhaust
tuned by james short
dyno on shortuning dyno
there is a pic of my cam specs and a pic of my dyno sheet
why do you all think my hp is so low i was shooting for 380 to 400rwhp
custom grind cam
411 pcm swap
ls2 timing chain
ported ls6 oil pump
