99 lq4/700r4
hi, i used the flat flexplate and spacer with longer bolts from another lq4 but with a 4l80, you just have to elongate the holes to correctly bolt up the torque converter
http://www.thirdgen.org/techboard/lt...tml?highlight=
check this thread out. and also follow the threads of:
3.1EyeCandy
Diabloformula
3.1EyeCandy
Diabloformula
The 99 and 00 Lq4 Had a longer crank snout in the rear. I am not sure how you would be able to make it work with the 700r4 which is basically similar to a 4l60e. I believe you would have to have the rear snout turned down or use a later crank from an 01 up engine.
The 01 up rear crank snout is shorter and uses a spacer to get it to work with a 4L80E to use an 01 up LQ4 with a 4L60E you have to remove the spacer. You may also have to use an LS1 Fly wheel Or a 4.8/5.3L Fly wheel but I am not 100% sure on that....
FWIW the 99-00 wide rear crank snout is 1.250 wide. The Later 01-up Narrow flange is only .857 wide
You will have to elongate the holes as the bolt pattern on the older torque converter is slightly different.
You will also have to use the correct starter
I dont know about him, but I used a TV cable from a 3rd gen camaro with a V6 and 700r4. Then took the tab(used for cruise control)on the throttle body, cut it off and welded it 180 degrees out. Then mounted the cable in the same bracket as the throttle cable.
Also keep in mind when using a 700r4 behind a LS motor, you will have to recalibrate your governor so WOT upshifts dont happen at like 4500rpm.
i have a 5.3 and a 700r4 mated. i used the stock flywheel with a crank spacer, spacer on outside of flywheel so you can use your stock starter. the torque converter i purchased bolted right up without having to elongate any holes. (so u may get lucky). as far as the t v cable, i mounted a piece of metal on my throttle bracket to allow the tv to be pulled out as the throttle comes back. also had the motor tuned for "analog" style transmission, like it was a manual trans. its that easy..
