Any year LS1 to avoid?
Old 03-12-2009, 07:56 AM
sprbxr's Avatar
Default Any year LS1 to avoid?
Are there any year LS1 engines to avoid when doing a conversion?
Thanks
Justin
Old 03-12-2009, 09:53 AM
Pop N Wood's Avatar
The later ones (2001 and on) have improved oiling and some other internal block changes.
Old 03-12-2009, 09:58 AM
puggerton03's Avatar
look for an 01 or 02. but get what you can afford. there all good.
Old 03-12-2009, 10:42 AM
sprbxr's Avatar
How about an 03 from a Vette?
Old 03-12-2009, 11:55 AM
even better. get it.
Old 03-12-2009, 01:39 PM
bczee's Avatar
Latest and lowest miles is best.. but depending on what your going to use it for and how you drive it. Even a 97-98 can be a good value and be completely ok for a DD or crusier swap.
People will frame the older Gen III engine, but they can be a cheaper $ Swap if your just updating for a cruiser or driver.
Old 03-12-2009, 01:45 PM
Steve VanS's Avatar
2001 and newer deleted the EGR. One less thing to have to pass emissions testing.
Old 03-12-2009, 01:49 PM
Bad Blue WS6's Avatar
isnt the head flow different, and cam?
98/99 heads (853's?) not as good as 241's which are not as good as 243's
98/99/2000 cams were bigger than those found in the 01's and 02's.
Im not 100% on that but am trying to find out where i read that (was on here)
Old 03-12-2009, 06:02 PM
styoung's Avatar
i would say the only year to stray away from would be 98 f body because they run a different compter. but the later ones do have upgraded rod bolts and ls6 intakes and like said some improved oiling.
Old 03-12-2009, 06:30 PM
jomomma's Avatar
if you decide to go with forced induction, then dont go with a 98 if possible. they are`nt as tuner friendly as the 99-02 pcms
Old 03-12-2009, 06:35 PM
jetlag's Avatar
I'd go with 01 or newer because they already have the LS6 intake, no EGR to delete, 28.8# injectors, and newer.
Old 03-13-2009, 04:35 PM
sprbxr's Avatar
Thanks. I just put a deposit on an 03 from a Vette.
Quick Reply: Any year LS1 to avoid?
