Need help with a few wires
Old 05-18-2009, 01:08 AM
brianfromhawaii's Avatar
Default Need help with a few wires
I need a pinout guide on the wiring for the gauge cluster, and need to know what color wires do what going to the fuel pump thing that is riveted to the car.
Old 05-18-2009, 05:27 PM
CalEditor's Avatar
What kind of car?
Old 05-18-2009, 06:51 PM
2000 ta
Old 05-25-2009, 08:33 AM
CalEditor's Avatar
The IPC
Old 05-25-2009, 08:39 AM
CalEditor's Avatar
Are you talking about this?
Old 06-26-2009, 05:43 PM
yes i am!! and i need the two plugs that go through the firewall on the passenger side to the ecm.
Old 06-26-2009, 08:39 PM
CalEditor's Avatar
ok
00.doc
Old 06-26-2009, 08:49 PM
CalEditor's Avatar
Ok 220 230.doc
Old 06-30-2009, 08:04 PM
ugh. i also need wiring for the auto trans shifter! i guess there is some wires that come from the shifter that go somewhere.
Old 06-30-2009, 08:26 PM
CalEditor's Avatar
I will see what I can do
This week I hope to get the Blown Nightmare Mustang out, the Blown GMC a little more power and my wife is in town. The last time I saw her was Hmmmmmmmm Not sure. We had a lot of snow when I left. Hmmmmmm
I will get you that info asap
Old 06-30-2009, 09:24 PM
thanks man! if u could get it tonight thatd be great as im workin on the car tonight...
Old 07-01-2009, 07:45 AM
i also need the wiring for the 4 connectors that come from the ecu to the front of the car on the passenger side...
Old 07-01-2009, 05:24 PM
http://www.dxsoftware.com/magnus/wiring.htm
Old 07-01-2009, 05:26 PM
CalEditor's Avatar
(1) P100
(2) Foward Lamp Harness
(3) Engine Wiring Harness Junction Block 1
(4) Engine Wiring Harness Junction Block 2
(5) C102
(6) C100
(7) C105
(8) C101
(9) Powertrain Control Module (PCM)
(10) P110
(11) Vehicle Speed Sensor
(12) Engine Harness
Old 07-01-2009, 05:27 PM
CalEditor's Avatar
On the shifter or the Trans?
Old 07-01-2009, 05:37 PM
CalEditor's Avatar
00 Camaro C100, C101, C105.doc
Old 07-01-2009, 06:41 PM
shifter
Old 07-01-2009, 08:40 PM
CalEditor's Avatar
Old 07-01-2009, 08:54 PM
where did u go in alldata to find this? i have all data too but idk how to use it i guess
Old 07-01-2009, 08:58 PM
and how does the neutral safty switch interface with the starter? what wires go where....?
Quick Reply: Need help with a few wires
