LS1 into an 82 Malibu Wagon
Old 07-01-2009, 09:09 AM
jeeperanthony's Avatar
Default LS1 into an 82 Malibu Wagon
The plan is to put a 5.7 LS1 and 700r4 in. Here are the pics so far.
How it started.
How it ended up.
Day 2
Got the motor and trany out today, and started the cleanup.
2 questions. 1) How can I tell what tranny I have?
2) What accesories are you guys using to run A/C?
Lastnight
It is mocked up. Kinda. 2 Issues.
1) The oil pan hits the K-Member. Solution? I was thinking of putting a 1/4" plate in between the mount and the frame. This would also allow me to move the motor back some, as it seems a little far forward.
2)The compressor does not bolt up. Is there a bracket I am missing, or is there a different style compressor that would work better?
Also, what is everyones opinion on the placement front to back on the motor?
Old 07-01-2009, 10:08 AM
Darracq's Avatar
I put one in a malibu wagon a couple years ago. I made my own mounts i used upper and lower moroso solid and a 1/4 plate to the engine, drilled some holes to make it work, put the engine where i wanted it with the headers and drilled new holes in the cross member, didnt run ac or anything,
Old 07-01-2009, 11:26 AM
So you made your own engine side mounts and had moroso solids on the frame? Got any pics?
Old 07-01-2009, 11:36 AM
LS1 BU's Avatar
I've had my ls1/4l60e in my 80 bu for 8 years now. I had John B make the motor mounts and oil pan. That was 8 years ago and I have never looked back. For the time it would have taken to fab the mounts and modify the oil pan it was cheaper to buy them. Quality products from John B.
Old 07-01-2009, 11:42 AM
6SSPEED's Avatar
LS1 BU......How bout some pics? Subscribing to this thread
Old 07-01-2009, 12:33 PM
TTLS1GP's Avatar
count the bolts!
Image---Transmission(s)------------------------------Pan Bolts
1______Aluminum Powerglide ___________________14
2______TH200 (Metric), TH200C (Metric)___________11
3______TH250, TH250C, TH350, TH350C, TH375B___13
4______TH375C, TH400, TH475, 3L80, 3L80HD______13
5______TH200-4R_____________________________16
6______TH700-4R, 4L60, 4L60E__________________ 16
7______4L80E_________________________________17
Old 07-03-2009, 07:41 AM
We seem to be having trouble placing the motor. Does it need to be parallel, or does it need to be center? I can't seem to get both.
edit: I meant level, not parallel.
Old 07-03-2009, 08:32 AM
HTh3r0's Avatar
this will be cool once its ready
Old 07-03-2009, 09:48 AM
Pop N Wood's Avatar
it needs to be lined up with the rear diff. You can offset the motor in the engine bay and tilt it to your heart's content. But you want your U joint angles to line up.
This is a good write up. They have a link toward the the end for an alignment method that uses cheap laser pointers. Worked well for me.
http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Old 07-03-2009, 12:09 PM
lsxmalibu's Avatar
Im my wagon, I placed the motor all the way back to the firewall, then I had to use 1/2 blocks between the block mounts to raise the motor.
Old 07-04-2009, 08:35 AM
Thanks for the input guys! Now another question. Will the truck and car balancers bolt up the same? I saw the truck balancer doesn't hug the block so much possibly making room to move the motor back more.
Old 07-05-2009, 09:32 PM
Got the trans bolted in yesterday. Went as smoother than I could have imagined.
When I said center, I meant left to right. But I believe it is more important to have the trans point to the rear-end. Correct? Also, since the last update, I made 3/8" plates to put the motor mounts on. They are rough at the moment, but I cut them too big in purpose in case I found a reason to keep them that large. One thing that I did not snap a photo of though was the driveshaft. I have 2 of them. One from a late model silverado(Giant aluminum) and the stock one. Both are about an inch or so too long, so I gotta cut and weld. Which One should I use?
That is much better.
Quick Reply: LS1 into an 82 Malibu Wagon
