LT1 iroc swap need Help!!
TO make a long story short. My best freind died a lil while back and he started a Lt1 swap in a 86 iroc. So i'm finshing it for his dad. I have the motor and trans (4l60e) bolted in and all Acc drives r done. I need to know how to wire the ingition system. I"m using the stock harness from the 94 Ta the motor came from. is there anything speacial i have to do. i was told i have to by-pass the security system. any and all info will be a big help.
If i remember correctly wen i did an lt1 swap in a 91 GTA convertible i had to send the PCM away to get the VATS taken out and i used the painless LT1 wiring harness it was a long drawn out ordeal but the car worked pretty good wen we got it up and running
