LQ4/200r4 Stand Alone Harness INSIDE
OK I'm ready to start De-pinning my harness, i have the gray covers off of the C1 and C2 connectors. Ive got a LQ4/200r4. I will not have A/C or emissions. It's for my 1984 Buick Regal.
The following wires will be removed... I think... Question Marks are next to the ones I'm unsure of and need your help!!! Also I may be missing some that may need to be removed. I have looked at the lt1 swap website for info, and on here. I just need some reassurance that I'm going in the right direction thanks!
On the Blue Connector C1
17 - Transmission Fluid Pressure Switch Signal B
18 - Transmission Fluid Pressure Switch Signal C
23 - Low Reference
25 - HO2S Low Signal Bank 2 Sensor 2
28 - HO2S Low Signal Bank 1 Sensor 2
32 - Clutch Pedal Position Switch
34 - Neutral Safety Switch Signal
45 - 5-volt Reference A/C Refrigerant Pressure Sensor
46 - 5-volt Reference Fuel Tank Pressure Sensor
53 - Low Reference Transmission Temperature Sensor
65 - HO2S High Signal Bank 2 Sensor 2
68 - HO2S High Signal Bank 1 Sensor 2
70 - Oil Level Switch Signal
79 - Skip Shift Solenoid Control M/T or 3-2 Shift Solenoid Control A/T
On Red Connector C2
2 - TCC Solenoid
4 - Air Relay Coil Driver
6 - PC Solenoid Valve High Control Sol.A
8 - PC Solenoid Valve Low Control Sol.A
13 - Cruise Control Engage Signal
14 - A/C Refrigerant Pressure Sensor Signal
17 - A/C Request Signal
18 - A/C Compressor Clutch Supply Voltage
20 - VSS Low Signal (???)
21 - VSS High Signal (???)
30 - Fuel Enable Control (Keypass II) (???)
34 - EVAP Canister Purge Solenoid Control
36 - AIR Pump Relay Control
37 - Cruise Control Inhibit Signal
42 - TCC Solenoid Valve Control
43 - A/C Clutch Relay Control
44 - Reverse Lock Out Solenoid Control
45 - EVAP Canister Vent Solenoid Control
47 - 2 - 3 Shift Solenoid Valve Control
48 - 1 - 2 Shift Solenoid Valve Control
50 - VSS Signal (???)
51 - Trans Fluid Temp Sensor Signal
53 - Ignition Retard Signal
54 - Fuel Level Sensor Signal
57 - Fuel Level Sensor Signal
63 - Transmission Fluid Pressure Switch Signal A
64 - Fuel Tank Pressure Sensor Signal
23 - Low Reference
On Red Connector C2
2 - TCC Solenoid
23 - Low Reference
On Red Connector C2
2 - TCC Solenoid
23 - Low Reference
On Red Connector C2
2 - TCC Solenoid
arent you using the msd box?
Ok, i guess i just wanted to make sure im not removing a wire i might need later. what kind of fuse block would be good for my fuses/relays to mount to? i will be hitting up the junk yard this weekend.
I've been waiting on you and some pics !!!!! I used to live in Cal Park a loong time ago. Good luck with the build; im dying to start mine......
