(Carbed) Fuel Pump Problems...
Guys,
I've got a BG 220HR system in my Maverick, and it really SUCKS! Actually, it doesn't suck at all, I can't get it to pull from my tank. Like every other car I've seen, the pump is higher than the sump's pickup (come on, how many cars have you seen with the pump's pickup lower than the sump). This has been really aggravating on the street, every time the fuel pump loses suction, it never recovers. Are there any pumps that will work mounted above the tank without losing suction?
If you have any kind of leak in the plumbing between the pick up and the pump, even inside the tank, it will be like trying to drink a soda through a straw with a crack. Make sure everything is tight.
I would also check the inlet of the pump to make sure it doesn't have any debris or junk in it. Try pulling the pump and back flushing it. What type of prepump filter do you have?
Pump doesn't have to be below the tank, but as low as possible helps a lot. This is especially true when the fuel gets hot. The pump can cavitate when that happens.
Im using a bosch 044 pump on my car. It didnt appreciate pulling fuel up from the tank. I tried everything to make it work. I finally sumped it and it works perfect. Also the difference between summer and winter fuel makes a difference also. One will cavitate and aerate worse than the other. Cant remember which did it worse though. Be sure your filter isnt too tight too it should be 100 microns in front and 10 or 30 after.
I cut an access panel into my sump today, welded in a baffle, and altered the return line a bit. I'm waiting on parts, including a block of foam to get it back together.
Not really above the tank, the pump's center-line is about even with the 3/4" full point. I've tried leaving the cap off (I have a vented cap and a tank vent), no difference either way...
That's good to know, in fact, my son has a new A1000 that he's offered to lend me if I can't get this figured out.
Yup, tight (car sets in a closed garage and we never smell any fuel).
I've had the pump apart a dozen times, it always looks fresh. I had a BG-5000 (5 micron) ahead of the pump as per BG's recommendation, but moved it to after the pump today. Bought a 100 micon prefilter that'll be here Wed.
By moving the filter I was able to lower the pump another 2 1/2" so it's center-line is now at the 1/3 tank level.
I've looked at all kinds of install manuals on line and have never seen the phrase "self-priming" mentioned anywhere. Every manual I saw said the pump must be mounted below the sump. Do you know what brands for sure? Please post pix of your setup(s)! I've NEVER seen any sumped tank with a pump hanging below it.
Well, I can tell you this. I've pumped out the tank (using the fuel pump) 3x's so far by dumping the return line into a drum and I never get any aerated fuel, it's always a solid stream. BTW, this pump will dump 10 gals of fuel in less than 3 minutes. Time will tell, I'm off Monday but it's a 70% chance of rain. Hopefully I can get it back together.
On another note, while removing the fuel pump to mod the bracket, I noticed a pretty good rattlling noise. Come to find out, the vanes are short enough to make the noise, which may be why it won't pick up suction. I might try making my own vanes that are long enough to seal against the housing and cover plate...
