LS1 in my 97 Jeep TJ
Old 12-04-2009, 01:28 PM
pbj-tj's Avatar
Default LS1 in my 97 Jeep TJ
Figured since i've asked so many questions on this forum to help me do my motor swap, that I would share the actual build up.
Couple "Before" Pictures, at this point its pretty much stock except for the 3" body lift and 31" tires
Stock 4 banger still in there:
Old 12-04-2009, 01:37 PM
pbj-tj's Avatar
Pulling out the drivetrain:
Empty engine Bay & soon to be lift kit:
Old 12-04-2009, 01:40 PM
pbj-tj's Avatar
Tearing apart a blown-up 98 LS1 that I picked up
Old 12-04-2009, 01:45 PM
pbj-tj's Avatar
Gutting and Prepping the tub for Herculiner
Old 12-04-2009, 01:48 PM
pbj-tj's Avatar
Prepping the frame rails for the LS1 Motor Mounts
Old 12-04-2009, 01:51 PM
pbj-tj's Avatar
Howell programed PCM & Wiring Harness
4L60e 4x4 Transmission
Bell Housing
Old 12-04-2009, 01:56 PM
pbj-tj's Avatar
Freshly Rebuilt Motor, got a 5 axis job on the stock heads for a little bit better flow. Was considering doing aftermarket heads, Cam,Lifters forged internals,ported TB and LS6 intake, but being budget constrained, I just wanted to see how she would perform slightly better than stock for a little while, Slightly better meaning, Ported Heads, Cold air, Intake, No A/C, and an Xpipe exhaust setup
Old 12-04-2009, 01:58 PM
pbj-tj's Avatar
Swapped in a Ford 8.8 rear end to better handle the LS1 power, it will be much better than the stock Dana 35 that was previously in there:
Old 12-04-2009, 02:06 PM
pbj-tj's Avatar
Installing the Torque Converter, Flex Plate and motor mounts and attaching the trans: I would later have to take it all apart again, because I forgot to order and install the torque converter spacer that attaches to the crank pilot:
This is how I decided to attach the trans, because I do not own a transmission Jack "not recommended lol:
There's that spacer I needed!!...
Old 12-04-2009, 02:11 PM
pbj-tj's Avatar
Mocking up Accomidations for the Hurst Mega Shifter
Hurst Mega Shifter Installed:
Old 12-04-2009, 02:15 PM
pbj-tj's Avatar
Advance Adaptors - Aluminum Radiator and Spal Puller Fan:
Old 12-04-2009, 02:22 PM
pbj-tj's Avatar
Radiator installed in Front Grill, Cleaning up the Exhaust Manifolds & Put the Accessory drive on the motor:
Old 12-04-2009, 02:24 PM
pbj-tj's Avatar
Pioneer AVIC-D3 in the dash:
Old 12-04-2009, 02:31 PM
pbj-tj's Avatar
Pretty much the coolest day of my life, taking the Jeep and the motor to the fab shop, and get'n er Done:
Test fitting the motor and drivetrain:
First Test Fit:
Old 12-04-2009, 02:32 PM
pbj-tj's Avatar
Motor Mounts, Custom Cross Member, and the LS1 sitting in the Jeep!
Custom Cross Member:
Final Welds & Motor in:
Old 12-04-2009, 02:42 PM
pbj-tj's Avatar
So I pretty much started this project last March, its come a long way.
Tons of research and headaches especially being a newbie, and this being my first project of this magnatude. In the end though I see it all being worth the effort.
Things left on the to-do list:
-Slip Yoke eliminator kit on the transfer case
-Custom front and rear drive shafts
-Plumb the new fuel system
-Make the cold-air intake fit
-install PCV system
-finish connecting the rest of the wiring harness
-bleed the brakes
-Install the Exhaust System
-And then finally fire up the motor for the first time:
More info and updates to come, I should be driving it (Daily Driver) by Mid January 2010.
Feel free to ask questions! I left tons of details out, just wanted to post up a quick summary of my project.
Old 12-04-2009, 03:20 PM
Shon Herron's Avatar
We do it like this!
These are 5.3s but the same idea.
This one is a 5.3 with a small cam in SDOL
This one is a stock 5.3 with a Ford 4spd Manual Tranny
Old 12-04-2009, 03:49 PM
pbj-tj's Avatar
Cool rigs man, I was gonna do a 4 link suspension but for 3-4 thousand dollars, I changed my mind real quick lol. This is gonna be my daily driver so I didnt want to get to crazy "yet" who knows what else i'll decide to do. For now I'll be happy with the power, and my 4" short arm lift, it'll be able to do everything and more for my needs.
Old 12-04-2009, 03:51 PM
I will load up the DD 5.3/700R4 Jeep that was done too. Its the cleanest install I have ever seen!
For a DD what you got will be fun!!!
Old 12-04-2009, 04:55 PM
pbj-tj's Avatar
Sounds cool man, post it on up!
Quick Reply: LS1 in my 97 Jeep TJ
