Which alternator would be best for my LQ4 into an s10
Hey guys, im doing a carbed LQ4 into a first gen s10. I am using the truck bracketry and do not have an alternator yet. What would be the best alternator for wiring up in the s10? I do have a sbc style one wire alternator but it doesnt look like it will fit the truck bracketry. In the end it would need to fit the truck bracketry. Thanks fellas.
The pulley is located at corect depth so it will line up, but it will be closer to the block, so you'll need a shorter belt. Most likely you'll be running an Econoline pulley to get more clearance by the steering box, so you'd need a new belt anyway, since that pulley is also smaller
