LS3/4L70E into C4 Corvette
Old 03-20-2011, 03:47 PM
LSCha0s's Avatar
Very nice!!
I Just started a swap on my 91. I found your solution to the transmission problem very helpful. I hope you don't mind if I contact you for help with the wiring when the time comes.
Old 03-20-2011, 06:02 PM
GTMLS3's Avatar
Good post, information for my 91 Camaro with the LS3 and 4L80E
Old 03-21-2011, 10:31 PM
TurboS10's Avatar
Do you know somebody for the bi annual or ????
I'm doing an LS3 swap too so I am curious.
Old 04-19-2011, 04:06 PM
Agent13's Avatar
Forgot to update this thread...
Here it is at the dyno... It was dynoed on a Dyno Dynamics dyno. The tuner said that it might have some more in it, but we will have to dyno it in second gear due to the 2.59 rear maxing out the dyno speed.
http://www.youtube.com/watch?v=WYfYj...layer_embedded
Took the car down to the 1/8th a few weeks ago...This was my first time to the track in a while.
The conditions were 62.1 F 65 % Humidity 30.04 in Pressure
DA 689 feet above sea level.
My top three runs of the night were:
1. This was my final pass of the night. It was against a surprised C5 driver. He did a 8.216 @ 84.92
60' 1.864
1/8 7.927
MPH 91.09
2. Against C6 Z06. He did a 7.738 @ 98.78
60' 1.861
1/8 7.929
MPH 92.46
3. Against another C5 but he missed 2nd gear. 10.603 @ 45.60 for him.
60' 1.898
1/8 7.973
MPH 92.53
I need to purchase some tires now...
Next up is installing an A/C system on it... I'm still exploring my options but am looking to finish it up quick so I can take the car into paint in a few weeks.
Old 04-20-2011, 09:59 AM
Jeff Smith's Avatar
Looks nice Ls3 into C4. Does the motor mount change the position or same ?
Old 01-19-2013, 11:53 AM
roostaz24's Avatar
Default 4L70E to 700R4 tailshaft alignment
Originally Posted by Agent13
The tailshaft housing lines up perfectly with the adapter. The C-Beam had to be notched slightly.
Hi, I am looking to put the 4L70 in my 84 Vette. I have the 4L70 and just bought an 88 C4 tailshaft housing, which seems to be the correct parts. However, the tailshaft itself is too short to accomodate the new housing plus the 1.5'' 6 to 4 bolt adapter. Did you have to put in a longer tailshaft? It was not clear if you had changed just the tailshaft housing or changed tailshafts as well. Or did you extend the collar on the driveshaft to make up the difference?
Thanks.
Attached Thumbnails LS3/4L70E into C4 Corvette-2013-01-19_12-16-08_177_1.jpg
Quick Reply: LS3/4L70E into C4 Corvette
