1990 mustang swap 6.0-t56 magnum
Old 04-03-2010, 12:06 PM
crazystangg306's Avatar
Default 1990 mustang swap 6.0-t56 magnum
has anyone used the AJE caster camber plates . i think they sent me the wrong ones. if anyone has any pics of them on there car that would be awesome.
Thanks
http://lsxfox.hqforums.com/90-notch-vt80.html
Old 04-03-2010, 02:14 PM
dmracing's Avatar
What do yours look like? I have a set too and they dont fit me coupe either. Not only that but the powdercoating is flacking off them. They look like crap.
Old 04-03-2010, 02:28 PM
dmracing's Avatar
Heres what mine look like.
Old 04-03-2010, 04:29 PM
heres what they look like. they better do something about this. they sent me the wrong cross member 3 times. and the bad thing is they called me and told me it was wrong.
Old 04-03-2010, 05:11 PM
dmracing's Avatar
Those are supposed to be the new universal ones. They dont fit. I have the version before those. I was gonna order a set of those one too.
Old 04-03-2010, 05:27 PM
Yeah they don't fit . i found this in my searches but they don't look nothing like the ones i have. the ones i have have 7 & 8 STRAIGHT EDGES THERE SIT SAYS 6 & 7 for the drivers side and passenger side. sent them a email but i will be on the phone with them early Monday morning.
http://www.popularhotrodding.com/fea...ck/shocks.html
looks like you have to Cut the top of the strut tower. And i just had the engine bay painted
mine might be for sale if they say i have to cut the tower
Old 04-03-2010, 05:41 PM
dmracing's Avatar
Some chassis fabricators do that for more angle at the track. I believe you dont have to cut the towers for them to work.
Old 04-03-2010, 06:25 PM
Some chassis fabricators do that for more angle at the track. I believe you don't have to cut the towers for them to work.
well i got them in there . opened up the bolt holes a lil bit. but you can only get to one of the adjustment screws. and the strut bolt hits the tower. both sides. looks like i will be doing some more grinding. i will post some pics in a bit . gonna charge up the camera and stop using the phone. where about downriver are you located ?
Old 04-03-2010, 07:05 PM
key4's Avatar
Ive got the aje caster camber plates too. I didnt care a whole lot for coming underneath the car but have heard thats better for drag racing. I also had to do some grinding for the strut bolts too. Post pics so I can make sure I got mine right. I was confused and the directions where terrible.
Old 04-03-2010, 07:18 PM
dmracing's Avatar
Sorry, Ive been in and out. Running around getting last minute Easter things. I live in Lincoln Park, Dix and Moran area.
Old 04-03-2010, 08:30 PM
That's funny i stay like 3 minutes away from you in Ecorse
Old 04-03-2010, 10:33 PM
dmracing's Avatar
Let me know what all you needed to do to make them fit?
Old 04-05-2010, 01:29 PM
Well After playing phone tag with AJE Racing. They told me that i have to make them fit by drilling new bolt holes. they told me to center the caster camber plate and drill new holes. because ford made two different bolt patterns. looks like i might be going to get new caster camber plates from Team Z.
Old 04-05-2010, 11:23 PM
I opened up the bolt holes and opened up the strut tower bolt hole. here is a before and after of the passenger side. I still have to do the driver side. then repaint the tops of the tower's o yeah and to get the drivers side plate to work. I had to grind on the caster camber plate a lil bit. i will get some pics of that when i get home from work tomorrow
Attached Thumbnails 1990 mustang swap 6.0-t56 magnum-imag0057.jpg   1990 mustang swap 6.0-t56 magnum-imag0059.jpg
Quick Reply: 1990 mustang swap 6.0-t56 magnum
