lex sc400+5.3 +th350+75mm turbo.
Old 11-05-2010, 09:37 PM
gallo-lo's Avatar
Arrow lex sc400+5.3 +th350+75mm turbo.
whats up forum!!!! im getting ready to convert my sc400 into lsx breed, got
-01 ,5.3 truck motor/w pcm& wiring harnes.
-th350 with 3400stall tc.
-75mm /t-6 1.08ar
things that im looking into.
-zo6 cam,
-317 heads,using cometic gasket .040 thick.
-injectorsmaybe 60lbs.
-air to water IC.
im looking to stay with the stock rear gear ratio 3.97,the car weighs in 3400lbs with the toyotav8,im going to diet it down to 2900lbs when its lsx converted,the doors are heavy. hoefully i should start working on this by next month . im looking for ideas ,opinions, and interesting information that i would benefit.
Old 11-05-2010, 09:40 PM
Civette's Avatar
Doing this same swap for a friend
Old 11-05-2010, 10:07 PM
gallo-lo's Avatar
got any pics?
Old 11-06-2010, 12:39 AM
mulletnotch's Avatar
Ditch the LS6 cam if you're planning on keeping those short gears and not having overdrive you are gonna need alot more RPM than what the LS6 cam will support..... The LS6 will be done more or less by 6k. I switched from the LS6 cam on my stock LQ4 motor to an Ed Curtis/FlowTech Induction cam and gained a little over 100rwhp at the same boost and a TON of graph making power all the way to 7k. 60lbers will support a little over 700rwhp(750ish) with raised base fuel pressure. Those 3.9X rear gears are gonna suck without OD with boost. For instance with 3.73's my mustang ran out of gear right at the 1000ft mark on 28in tall tires at 136mph making only 655rwhp....
Old 11-06-2010, 09:27 PM
gallo-lo's Avatar
i might have set of 3.34 gears, you have good points... il cha t with u soon,thanks.
Old 11-06-2010, 09:48 PM
zipster's Avatar
[QUOTE
-zo6 cam,
[/QUOTE]
gallo-lo,
where are you located? I've got 317 heads and would swap you your 5.3 heads if you want.
Let me know.
Old 11-07-2010, 05:26 PM
gallo-lo's Avatar
Originally Posted by zipster
[QUOTE
-zo6 cam,
gallo-lo,
Let me know.[/QUOTE]
how mch? im out in long island ny 11784.
are the they stock? no mill,porting?
Old 11-07-2010, 08:29 PM
Stancel's Avatar
I am building a Lexus IS300. Here are some quick ways to lose weight:
If your seats are like mine then they weigh a ton
Sunroof was around 35 pounds I think
My doors are cut down to just the skins
The rest was a bunch of small stuff.
I have gutted my car and it still weighs 2920 with half a tank of gas and no driver.
Old 11-07-2010, 08:41 PM
gallo-lo's Avatar
i was workin on it today, CLEANIN up the engine bay .
-all the cruise contral.
-ac crap.
i havent gotten into the interior yet,im thinking of slappin in a ford 8.8 rear with adj coil overs anit roll bar set up.
Old 11-10-2010, 08:54 PM
gallo-lo's Avatar
[QUOTE=Stancel;14091869]I am building a Lexus IS300. Here are some quick ways to lose weight:
I have gutted my car and it still weighs 2920 with half a tank of gas and no driver.[/hey any updates?
Old 11-10-2010, 11:24 PM
ZTwentyAteU's Avatar
those 3.90 gears might hurt the spooling time
looks like a cool swap
Old 12-20-2010, 03:12 PM
Stancel's Avatar
hey any updates?
Yeah, I have a full roll cage and race seats in the car now. I am still collecting parts for my swap so no engine bay work to speak of.
Quick Reply: lex sc400+5.3 +th350+75mm turbo.
