fbody accessories
Old 02-05-2011, 10:51 AM
merim123's Avatar
Default fbody accessories
I'm trying to figure out if the cts-v accessories are exactly like the fbody. if so, getting all new parts for less than 800 is a pretty good deal.
fbody pic...
Old 02-05-2011, 12:09 PM
Jimbo1367's Avatar
not exactly. similar though
Old 02-05-2011, 12:16 PM
merim123's Avatar
i know it's a long shot, but if someone has one of these motors out with the accessories on there, and could confirm the measurements. it's only a few minutes of work, but finding someone that has the easy access is the the tough part
Old 02-05-2011, 03:19 PM
waxenate's Avatar
Is that pic from an fbody? If not they sure look similar....
Old 02-05-2011, 03:30 PM
merim123's Avatar
the picture is fbody. the diagram is what is available from GM right now as a full kit.
Old 02-05-2011, 03:47 PM
Pocket's Avatar
That diagram is from GM? Wow, not even close
The PS pump is different from F-body to GTO/CTS-V in being a detached reservoir. Most everything else looks the same but cross reference the bracket PNs at the dealership before going with it
Knowing GM, its likely similar to the B-body vs F-body LT1 accessories. Look identical but nothing interchanges directly
Old 02-05-2011, 04:23 PM
t72ss402's Avatar
And remember those kits do not include the water pump or harmonic balancer, so keep in mind that stuff will need to be purchased also.
Tim.
Old 02-05-2011, 05:36 PM
Deano1712's Avatar
The CTS-V and F-Body accessories are not interxhangeable. You need the LS3 damper and water pump for the former. The CTS-V belt is 22mm closer to the engine than the F-Body.
Quick Reply: fbody accessories
