ls1 intake on 5.3
ls1 intake on 5.3
hey guys im working on a 5.3 turbo build for my 79 malibu. i was wanting to swap the intake to the car style. but was wanting to know if i would gain anything by it? i know most if the people swap them for height problems but it not really a case in my car. i like the look of the car intake and i was thinking it may help out on top end? i know the truck intakes are more for torque?
Ya the car intake will prob give you alittle more top end, and yes the truck intake a little more torque down low. depends which you want more? if you are still using the stock truck accesories then the car intake will require a bit of screwing around to make it fit,like trimming the accesory bracket near the alternator and relocating that idler pulley, also the truck water pump outlet will interfere with the throttle body on a ls1 style intake i believe, also fuel rails, injectors etc you would need to get with the ls1 intake. IMO its not worth the hassle for the couple extra ponies you might pick up. Find a later model truck engine cover and spray it up nice and youl have a good looking package as is.
ok i guess i will stick with the truck intake for the time im working on the harness right now pain in the ***. it was dbw and im swapping to cable. thanks for the input guys i was trying i make up my mined before i sent off my computer to get the vats and crap remove. im having the guy from lt1swap.com do the tuning
